This guide explains how to remove the RAM chip from the HP 15-f009wm notebook computer. This could be done to either replace a malfunctioning chip or to upgrade to a larger chip.
Turn laptop upside down.
Flip the lock switch to the unlocked setting.
Flip the release switch.
Once the flip is switched, the battery should pop out.
Remove the two Phillips #1 screws from the RAM panel.
Use the plastic opening tool to pop the panel off.
Release the tabs on each side of the chip by simultaneously pushing each tab away from the RAM.
