This guide explains how to remove the Hard Drive from the HP 15-f009wm notebook computer. This could be done to either replace a corrupt Hard Drive or to upgrade to a larger Hard Drive.
Turn laptop upside down.
Flip the lock switch to the unlocked setting.
Flip the release switch.
Once the flip is switched, the battery should pop out.
Remove the two Phillips #1 screws from the RAM panel.
Use the plastic opening tool to pop the panel off.
Release the tabs on each side of the chip by simultaneously pushing each tab away from the RAM.
Remove the sixteen 7mm Phillips #1 screws from the bottom panel.
Pull the disk drive out of the laptop.
Remove the three 2mm Phillips #00 screws found underneath the disk drive.
Remove the single 4mm Phillips #1 screw from the Wi-Fi card.
Pull the Wi-Fi card out of the motherboard.
Open the laptop.
Use a plastic opening tool to pop out the keyboard by starting at the top and working your way around the perimeter.
Open the screen up until it lays flat and rotate the laptop until the screen is closest to you.
Lift the keyboard from the laptop.
Use a spudger to lift up the black latch on the ZIF connector and remove the ribbon cable.
Remove the five 7mm Phillips #1 screws found underneath the keyboard.
Use a spudger to lift the black tabs on the ZIF connectors.
Remove the ribbon cables from the ZIF connectors.
Use a plastic opening tool to pop the palm rest off of the laptop.
Lift and remove the palm rest.
Step 16 - Note
This repair guide is “almost perfect” for HP model 15-f100dx EXCEPT - removal of the Palm Rest - MUST REMOVE BACK (under Display Panel) FIRST! Attempting to remove using - the “Begin at front corner” method “WILL LIKELY CAUSE DAMAGE”. HP is generally pretty good about supplying service manuals. I find it interesting that many of the models within 15-xxxxdx series - no “online” manuals are available. I cannot say if these manuals were ever available and HP removed them from the support site, or they never existed. This genre was during the time HP was having heat issues and conflicts with “nVidia” over “WHO was actually to blame for the heat issues”. Nonetheless, at the end of the day it was and still is us lowly consumers (and repair Techs) that were and still are the MOST affected & damaged parties. Just my humble opinion…
Hope this helps,
Doug
Use a spudger to lift up the black latch on the ZIF connector.
Remove the USB/AUX port ribbon cable from the ZIF connector on the motherboard.
Remove the single 7mm Phillips #1 screw from the USB/AUX board.
Remove the USB/AUX board from the laptop.
Lift the Hard Drive from the laptop.
Disconnect the hard drive from the motherboard.
crwdns2935229:09crwdne2935229:0
This guide helped me so much with my laptop, thanks m8
Thank you for this excellent write-up!
Hello, i have a question. How much of capacity and technology i could use to upgrade my hard drive?
