This guide explains how to replace the storage drive on the HP 15-dy2072dx. The storage drive on this laptop is a solid state drive(SSD). A replacement may be necessary in case of drive failures or a need to upgrade to a greater storage space.
The storage drive is responsible for storing all your files, boot files, and the OS files. A replacement may be an exact part replacement or a upgrade to the amount of storage(i.e. 256 GB to 1 TB).
Caution to use ESD safe tools and ESD wrist strap as static discharge may damage the new drive or the motherboard.
Remove both of the rubber strips to uncover the hidden screws.
Unscrew all 8 Phillips #1 screws on the bottom panel:
Two M2.5x6
Six M2x6
Flip the laptop over and open the lid.
Separate the bottom panel from the main body by using the iFixit opening tool.
Close the laptop to allow the back edges to fully separate
Flip the laptop over and carefully remove the lower case.
Locate the storage drive.
Unscrew the single screw holding the drive in place.
Grab the drive by its side and gently pull it out.
