HP 15-dy2024nr Back Cover Replacement
  1. HP 15-dy2024nr Back Cover Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-dy2024nr Back Cover Replacement, Back Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to peel one corner of each of the rubber feet from the bottom of the laptop.
    • Gently peel the feet from the laptop using the spudger revealing the screws underneath.
    • If the rubber foot peels away but leaves adhesive behind you must peel the adhesive away before removing the screws.
  2. HP 15-dy2024nr Back Cover Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 15-dy2024nr Back Cover Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 15-dy2024nr Back Cover Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove:
    • Two 2.5mm x 6mm screws
    • Six 2mm x 6mm screws
    • Be sure to keep different screw sizes separated.
  3. HP 15-dy2024nr Back Cover Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 15-dy2024nr Back Cover Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 15-dy2024nr Back Cover Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert an iFixit opening tool into the seam between the keyboard area and bottom cover.
    • Using another iFixit opening tool, slide along the seam to unhook the clips.
    • There are clips all the way around the seam. You may hear a popping sound as the clips come loose. This step may require some force to separate the back cover from the laptop.
    • When the front of the laptop is open, you can use your finger to hold a corner open then slide an iFixit opening tool along the seam toward the back corner.
    • After the clips have been released, flip the laptop over and lift the cover.
Konnor Young
crwdns2935283:009/27/22crwdne2935283:0
535 crwdns2915208:0crwdne2915208:0
Utah Tech University, Team 1-4, McMurrin Fall 2022 crwdns2935289:0Utah Tech University, Team 1-4, McMurrin Fall 2022crwdne2935289:0
UTAHTECH-MCMURRIN-F22S1G4
crwdns2936753:030crwdne2936753:0 36
crwdns2942667:0crwdne2942667:0 1,567
