HP 15-dy Rubber Feet Replacement
  1. HP 15-dy Rubber Feet Replacement, Flip your laptop over: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip your laptop over so the rubber feet are facing up.
  2. HP 15-dy Rubber Feet Replacement, Peel up an end of the front foot: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 15-dy Rubber Feet Replacement, Peel up an end of the front foot: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 15-dy Rubber Feet Replacement, Peel up an end of the front foot: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The rubber feet cover a total of six back cover screws.
    • Use an opening pick to peel up an end of the front rubber foot until you can grip it with your fingers.
    • Make sure both the foot and its adhesive peel up together, as they need to be removed as one piece.
  3. HP 15-dy Rubber Feet Replacement, Remove the front foot: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 15-dy Rubber Feet Replacement, Remove the front foot: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 15-dy Rubber Feet Replacement, Remove the front foot: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel the front foot away from the back cover and remove it.
  4. HP 15-dy Rubber Feet Replacement, Remove the rear foot: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 15-dy Rubber Feet Replacement, Remove the rear foot: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 15-dy Rubber Feet Replacement, Remove the rear foot: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use an opening pick to peel up an end of the rear rubber foot until you can grip it with your fingers.
    • Peel the rear foot away from the back cover and remove it.
  5. HP 15-dy Rubber Feet Replacement, Reassembly information: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 15-dy Rubber Feet Replacement, Reassembly information: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 15-dy Rubber Feet Replacement, Reassembly information: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Tesa 61395 Tape
    $5.99
    • Note that the rubber feet are different:
    • The rear foot is thicker, with a deeper recess.
    • The front foot is thinner, with a shallower recess.
    • During reassembly:
    • If you're reusing the rubber feet, the leftover adhesive should be tacky enough to reuse.
    • If the leftover adhesive isn't sticky enough or your replacement feet didn't come with adhesive, you can use double-sided tape such as Tesa Tape to secure the feet.
    • Make sure the strips of tape aren't wider than 6 mm, otherwise they may not fit.
    • To install a foot, remove its adhesive liner, lay the foot into its matching recess, and press down firmly along the entire length of the foot to secure it.
    The place in the rear is deeper than the front!
    Kevin “Caoimhín” Cotham - crwdns2934203:0crwdne2934203:0
    Thank you for the comment, the guide has been updated!
    Spencer Day -
Spencer Day
crwdns2935283:009/14/22crwdne2935283:0
119 647 crwdns2915208:0crwdne2915208:0
crwdns2935297:0838crwdne2935297:0
Staff
crwdns2931471:0119crwdne2931471:0
crwdns2935297:022 002crwdne2935297:0
Where can you buy new rubber feet for the 15-dy5885wm?
K. Wright - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 52
crwdns2942667:0crwdne2942667:0 2,284
