HP 15-dy Rubber Feet Replacement
  1. HP 15-dy Rubber Feet Replacement, Flip your laptop over: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip your laptop over so the rubber feet are facing up.
  2. HP 15-dy Rubber Feet Replacement, Peel up an end of the front foot: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 15-dy Rubber Feet Replacement, Peel up an end of the front foot: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 15-dy Rubber Feet Replacement, Peel up an end of the front foot: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The rubber feet cover a total of six back cover screws.
    • Use an opening pick to peel up an end of the front rubber foot until you can grip it with your fingers.
    • Make sure both the foot and its adhesive peel up together, as they need to be removed as one piece.
  3. HP 15-dy Rubber Feet Replacement, Remove the front foot: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 15-dy Rubber Feet Replacement, Remove the front foot: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 15-dy Rubber Feet Replacement, Remove the front foot: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel the front foot away from the back cover and remove it.
  4. HP 15-dy Rubber Feet Replacement, Remove the rear foot: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 15-dy Rubber Feet Replacement, Remove the rear foot: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 15-dy Rubber Feet Replacement, Remove the rear foot: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use an opening pick to peel up an end of the rear rubber foot until you can grip it with your fingers.
    • Peel the rear foot away from the back cover and remove it.
  5. HP 15-dy Rubber Feet Replacement, Reassembly information: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 15-dy Rubber Feet Replacement, Reassembly information: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 15-dy Rubber Feet Replacement, Reassembly information: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Tesa 61395 Tape
    $5.99
    • Note that the rubber feet are different:
    • The rear foot is thicker, with a deeper recess.
    • The front foot is thinner, with a shallower recess.
    • During reassembly:
    • If you're reusing the rubber feet, the leftover adhesive should be tacky enough to reuse.
    • If the leftover adhesive isn't sticky enough or your replacement feet didn't come with adhesive, you can use double-sided tape such as Tesa Tape to secure the feet.
    • Make sure the strips of tape aren't wider than 6 mm, otherwise they may not fit.
    • To install a foot, remove its adhesive liner, lay the foot into its matching recess, and press down firmly along the entire length of the foot to secure it.
Spencer Day
crwdns2935283:009/14/22crwdne2935283:0
130,565 crwdns2915208:0crwdne2915208:0
crwdns2935297:0884crwdne2935297:0
Staff
crwdns2935297:023,259crwdne2935297:0
Where can you buy new rubber feet for the 15-dy5885wm?
K. Wright - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 85
crwdns2942667:0crwdne2942667:0 2,500
