HP 15-dw0037wm Display Assembly Replacement
  1. HP 15-dw0037wm Display Assembly Replacement, Lower Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-dw0037wm Display Assembly Replacement, Lower Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin, discharge your laptop battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your laptop and disconnect the charger and any peripheries before beginning disassembly.
    • Set the laptop down with the lower case facing up.
    • Lift a corner of the lower silicone foot and peel it completely off.
    • Repeat for the upper silicone foot.
  2. HP 15-dw0037wm Display Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-dw0037wm Display Assembly Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the five 8 mm screws.
    • Remove the two 5 mm Phillips screws.
  3. HP 15-dw0037wm Display Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 15-dw0037wm Display Assembly Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 15-dw0037wm Display Assembly Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert an opening pick into the gap between the lower case and chassis.
    • Starting from a corner is recommended.
    • Slide the pick around the entire perimeter of the device until the lower case fully releases.
    • Remove the lower case.
  4. HP 15-dw0037wm Display Assembly Replacement, Display Assembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 15-dw0037wm Display Assembly Replacement, Display Assembly: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 15-dw0037wm Display Assembly Replacement, Display Assembly: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Detach the coaxial connector by grabbing it securely from the gold colored metal section and gently lifting upwards.
    • Don't tug on it from the white end or towards the side. It is likely to get damaged.
  5. HP 15-dw0037wm Display Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 15-dw0037wm Display Assembly Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 15-dw0037wm Display Assembly Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four 4 mm Phillips screws that secure the two hinges.
  6. HP 15-dw0037wm Display Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 15-dw0037wm Display Assembly Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 15-dw0037wm Display Assembly Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip up the black locking flap on the ZIF connector.
    • Disconnect the display cable.
  7. HP 15-dw0037wm Display Assembly Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 15-dw0037wm Display Assembly Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 15-dw0037wm Display Assembly Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use an opening tool to lift up the hinges.
    • Grab the hinge and pull it outwards.
    • Repeat onto the other hinge.
  8. HP 15-dw0037wm Display Assembly Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 15-dw0037wm Display Assembly Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 15-dw0037wm Display Assembly Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently grab the plastic cover and use both hands to lift it slowly from one side to the other.
    • Lift up the plastic cover to fully detach it.
  9. HP 15-dw0037wm Display Assembly Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 15-dw0037wm Display Assembly Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 15-dw0037wm Display Assembly Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the six silver 4 mm Phillips screws that secure the hinges to the screen.
    • Remove the two black 4 mm Phillips screws.
    • Be careful when removing the screws because it's possible that the foil underneath and the threaded hole itself can come off.
  10. HP 15-dw0037wm Display Assembly Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 15-dw0037wm Display Assembly Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 15-dw0037wm Display Assembly Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift up the hinge from the lower half and gradually separate it from the screen.
    • Repeat on the other side.
Emily Davila
crwdns2935283:008/28/24crwdne2935283:0
651 crwdns2915208:0crwdne2915208:0
University of North Texas, Team 1-5, Kilpatrick Fall 2024 crwdns2935289:0University of North Texas, Team 1-5, Kilpatrick Fall 2024crwdne2935289:0
UNT-KILPATRICK-F24S1G5
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 175
