Use this guide if the SD card reader or the USB drive located on the right side of the HP 15-db0015dx laptop stops working. Before starting this guide be sure to eject the SD card inside the laptop if applicable, remove any USB connectors and fully power off the device.
Power off the device before starting.
Remove the rubber strips that hide the screws using the spudger.
Flip the device and unscrew the eleven screws with a Phillips #0 screwdriver.
Use the spudger tool to pry open the back cover.
Lift the back panel to access the inside.
Slide the CD drive to the left, and remove.
Unscrew the three battery screws with a Phillips #0 screwdriver.
Lift the battery up, disconnecting the connector first.
Push forward and remove the battery.
Remove the four screws on the hard drive bracket with a Phillips #0 screwdriver.
Pull the hard drive bracket out.
Remove the hard drive from the connector by sliding it to the left until the connector is disengaged.
Lift up on the connector pin that attaches the SD card reader to the motherboard
Gently pull the wire out
Snake the wire underneath the battery support
Pull the wire out to allow the SD Card reader to be removed
Remove the two Phillips #0 screws holding the SD Card reader in place.
Gently pull the SD card reader up and out of the slot.
