HP 15-db0015dx Fan and Heat Sink Replacement
  1. HP 15-db0015dx Fan and Heat Sink Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-db0015dx Fan and Heat Sink Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Power off the device before starting.
    • Remove the rubber strips that hide the screws using the spudger.
    • Flip the device and unscrew the eleven screws with a Phillips #0 screwdriver.
    How can I remove the rubber strips? Which screwdriver head should I use?
    Alex Watkins - crwdns2934203:0crwdne2934203:0
  2. HP 15-db0015dx Fan and Heat Sink Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 15-db0015dx Fan and Heat Sink Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 15-db0015dx Fan and Heat Sink Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the spudger tool to pry open the back cover.
    • Lift the back panel to access the inside.
    • Slide the CD drive to the left, and remove.
    The top of what? Note that iFixit does not like arrows, and this arrow doesn’t seem to make sense here when you’re lifting up. Instead, use a flipbook style shot to show this action. I would also separate out the yellow bullet to a new step so you have three images to show this process, and also, so you can add more details to the description of what to do.
    I believe the tool here is the spudger, which you have in the tool list as well. Make sure to correctly identify tools.
    I suggest that you remove the CD-DVD drive BEFORE removing the back cover.
    Michael Maxson - crwdns2934203:0crwdne2934203:0
  3. HP 15-db0015dx Fan and Heat Sink Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 15-db0015dx Fan and Heat Sink Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 15-db0015dx Fan and Heat Sink Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the three battery screws with a Phillips #0 screwdriver.
    • Lift the battery up, disconnecting the connector first.
    • Push forward and remove the battery.
    What is the orange highlighted section? You want the text and images to work independently. The picture also seems to contradict what you say, since your hands are on the sides. Reminder: remove arrows in all pictures in favor of action shots.
    Add warning and info bullets to let the audience know that they may damage other sections of this computer by pulling pieces off.
    Alec Diaz - crwdns2934203:0crwdne2934203:0
  4. HP 15-db0015dx Fan and Heat Sink Replacement, Fan and Heat Sink: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screw on the fan with a Phillips #0 screwdriver.
  5. HP 15-db0015dx Fan and Heat Sink Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 15-db0015dx Fan and Heat Sink Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 15-db0015dx Fan and Heat Sink Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the fan upward slightly.
    • Be careful not to pull hard as the wires could become damaged.
    • Disconnect the fan cable by pinching on the sides of the connectors and sliding it out.
    • Lift the rest of the way to remove the fan.
    All subsequent steps in this heat sink need additional detail in directions and images.
  6. HP 15-db0015dx Fan and Heat Sink Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-db0015dx Fan and Heat Sink Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four screws with a Phillips #00 screwdriver.
    • Lift and remove the heat sink.
    • Remember to clean and reapply the thermal paste during reinstallation to retain proper heat transfer from the CPU. Check out this Thermal Paste Application guide if you are unfamiliar with the process.
Brandon Hirtz
crwdns2935283:001/29/20crwdne2935283:0
97 crwdns2915208:0crwdne2915208:0
Embry-Riddle Aeronautical University, Team S2-G5, Watkins Spring 2020 crwdns2935289:0Embry-Riddle Aeronautical University, Team S2-G5, Watkins Spring 2020crwdne2935289:0
ERAU-WATKINS-S20S2G5
Hey great guide! Just a quick question: is the material directly under the copper pipe (on the CPU side) also thermal paste which needs to be swapped out? Or is ist a static part of the fan/pipe/CPU cover? Thanks in advance!
Aaron P - crwdns2934203:0crwdne2934203:0
It's best to remove the material on both the CPU side and the attached fan side.
Terri Alexander - crwdns2934203:0crwdne2934203:0
did the fan replacement, want to do thermal paste replacement now. 3 of the 4 screws holding the heat sink bracket are stripped on mine... I need to know what size they are for replacement... any help there?
Lisa Nia - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,439
