If your device is failing to reboot or save your short-term data, then the RAM might need to be checked or replaced. The RAM specializes in saving short-term data for the device to function properly.
Flip your laptop over, face down.
Peel off the two long rubber grips running lengthwise on the laptop.
Using a Phillips #000 screwdriver, remove the eleven 10 mm screws located on the underside of the laptop, that are holding the back panel in place.
Carefully slide the optical drive out of the laptop.
Use a plastic opening tool to separate the back panel from the laptop.
Gently pull apart the two silver arms securing the RAM until it slightly flips up.
Pull the RAM directly out of its port.
