HP 15-db0004dx Fan Replacement
    1. HP 15-db0004dx Fan Replacement, Bottom Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-db0004dx Fan Replacement, Bottom Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Turn the laptop off and unplug it before starting.
      • Flip your laptop over, face down.
    2. HP 15-db0004dx Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Peel off the two long rubber grips running lengthwise on the laptop.
    3. HP 15-db0004dx Fan Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-db0004dx Fan Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using a Phillips #000 screwdriver, remove the eleven 10 mm screws located on the underside of the laptop, that are holding the back panel in place.
    4. HP 15-db0004dx Fan Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Carefully slide the optical drive out of the laptop.
    5. HP 15-db0004dx Fan Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a plastic opening tool to separate the back panel from the laptop.
      • For an easier removal, start at the corner and run the tool along the edge of the cover.
      • If you do not have a plastic opening tool, open it carefully using your hands, as shown.
      • Be careful to not bend the back panel, or to not apply too much pressure and force, doing so could cause the panel to break.
    1. HP 15-db0004dx Fan Replacement, Fan: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 15-db0004dx Fan Replacement, Fan: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 15-db0004dx Fan Replacement, Fan: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Using a Phillips #000 screwdriver remove the 5mm screw holding the fan in place.
    2. HP 15-db0004dx Fan Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 15-db0004dx Fan Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 15-db0004dx Fan Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • After the screw is removed, carefully unplug the set of wires with one of each colored, red, black, yellow, and blue, from the white connector it is secured at.
      • To unplug it gently pull the white connector from the adapter, possibly in a back and forth motion to free it.
      • DO NOT pull on the wires, doing so could cause damage to the wires, or for them to become disconnected to the white adapter they are attached to.
    3. HP 15-db0004dx Fan Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 15-db0004dx Fan Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 15-db0004dx Fan Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Carefully remove the fan from the laptop.
      • Be careful with removal as to not bend or break anything. There is a metal peg shown in the image, that the fan is secured on that could potentially bend
Britanni Arizola
crwdns2935283:009/22/22crwdne2935283:0
586 crwdns2915208:0crwdne2915208:0
University of North Texas, Team 4-5, Saru Jimmy Fall 2022 crwdns2935289:0University of North Texas, Team 4-5, Saru Jimmy Fall 2022crwdne2935289:0
UNT-SARU JIMMY-F22S4G5
crwdns2936753:030crwdne2936753:0 42
crwdns2942667:0crwdne2942667:0 519
