If the laptop does not boot correctly after running the "Startup Repair" from the Windows 10 DVD, use this guide to remove and replace your SSD. You will need a plastic opening tool and a Phillips #1 screwdriver head.
Turn your laptop over so that the Laptop Identification Tag on the underside of the laptop faces the ceiling.
Using the plastic opening tools, peel back the plastic feet from the underside of the laptop.
Using a Phillips #1 screwdriver, remove the eleven 9.0 mm screws holding the back cover in place.
Slide the optical drive out of the computer.
You have to turn the Computer back on to get the optical drive out
This step is missing information on how to one the optical drive it doesn’t just “slide out” like the picture
You have to power the laptop to get the OD out. Also I had a metal piece fall out of lower right corner and can't figure out where it goes. 😕
Flip the computer over and open the screen.
Start from a corner and run the plastic opening tools along the edge of the back cover.
After the cover has been completely loosened around the entire perimeter, close the screen and flip the computer over.
Gently pry back the cover starting from the middle, bottom edge.
Using the Phillips #1 screwdriver, remove the three 8.0 mm screws holding the battery in place.
Remove the battery by tilting the top of the battery towards you and pulling the battery away from the mounting tabs.
Using the Phillips #1 screwdriver, remove the single 3.0 mm screw holding the SSD module in place.
Pull the SSD module away from the socket.
Nice explanation about how to disassemble of hp laptop and assembly of SSD again in this video. Thanks this help me a lot. If you need assistance in Delhi ncr. Kindly call us
