HP 15-da0012dx SSD Replacement
Xavier Hung
crwdns2944107:0crwdnd2944107:0Xavier Hungcrwdnd2944107:0crwdnd2944107:0crwdnd2944107:05crwdnd2944107:0crwdne2944107:0
crwdns2944111:0August 1, 2023crwdne2944111:0
crwdns2931287:020crwdne2931287:0
crwdns2937801:0crwdne2937801:0
crwdns2862591:0crwdne2862591:0
crwdns2942287:0crwdne2942287:0
If the laptop does not boot correctly after running the "Startup Repair" from the Windows 10 DVD, use this guide to remove and replace your SSD. You will need a plastic opening tool and a Phillips #1 screwdriver head.
crwdns2942215:0crwdne2942215:0
crwdns2942339:0crwdne2942339:0
crwdns2944105:0crwdne2944105:0
  1. HP 15-da0012dx SSD Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-da0012dx SSD Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Power down your laptop before proceeding.
    • Turn your laptop over so that the Laptop Identification Tag on the underside of the laptop faces the ceiling.
  2. HP 15-da0012dx SSD Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 15-da0012dx SSD Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 15-da0012dx SSD Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the plastic opening tools, peel back the plastic feet from the underside of the laptop.
  3. HP 15-da0012dx SSD Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-da0012dx SSD Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #1 screwdriver, remove the eleven 9.0 mm screws holding the back cover in place.
  4. HP 15-da0012dx SSD Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-da0012dx SSD Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the optical drive out of the computer.
    You have to turn the Computer back on to get the optical drive out
    james john - crwdns2934203:0crwdne2934203:0
    This step is missing information on how to one the optical drive it doesn’t just “slide out” like the picture
    You have to power the laptop to get the OD out. Also I had a metal piece fall out of lower right corner and can't figure out where it goes. 😕
    Bob Watts - crwdns2934203:0crwdne2934203:0
  5. HP 15-da0012dx SSD Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 15-da0012dx SSD Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 15-da0012dx SSD Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the computer over and open the screen.
    • Start from a corner and run the plastic opening tools along the edge of the back cover.
    • After the cover has been completely loosened around the entire perimeter, close the screen and flip the computer over.
    • Gently pry back the cover starting from the middle, bottom edge.
    • Make sure not to bend or crack the plastic cover.
  6. HP 15-da0012dx SSD Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-da0012dx SSD Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the Phillips #1 screwdriver, remove the three 8.0 mm screws holding the battery in place.
  7. HP 15-da0012dx SSD Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-da0012dx SSD Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery by tilting the top of the battery towards you and pulling the battery away from the mounting tabs.
    Excellent directions! Thank you!
    Mary Sczech - crwdns2934203:0crwdne2934203:0
  8. HP 15-da0012dx SSD Replacement, SSD: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-da0012dx SSD Replacement, SSD: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the Phillips #1 screwdriver, remove the single 3.0 mm screw holding the SSD module in place.
  9. HP 15-da0012dx SSD Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-da0012dx SSD Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the SSD module away from the socket.
Xavier Hung
crwdns2935283:002/07/19crwdne2935283:0
977 crwdns2915208:0crwdne2915208:0
UC Davis, Team S20-G4, Lore Winter 2019 crwdns2935289:0UC Davis, Team S20-G4, Lore Winter 2019crwdne2935289:0
UCD-LORE-W19S20G4
Nice explanation about how to disassemble of hp laptop and assembly of SSD again in this video. Thanks this help me a lot. If you need assistance in Delhi ncr. Kindly call us
Mahima Singh - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 78
crwdns2942667:0crwdne2942667:0 9,631
