If the laptop only powers on when the power adapter is plugged in, use this guide to remove and replace the battery. You will need a plastic opening tool and a Phillips #1 screwdriver head. You will not need to perform any difficult steps, but separate the back cover from the laptop carefully.
Turn your laptop over so that the Laptop Identification Tag on the underside of the laptop faces the ceiling.
Using the plastic opening tools, peel back the plastic feet from the underside of the laptop.
Using a Phillips #1 screwdriver, remove the eleven 9.0 mm screws holding the back cover in place.
Slide the optical drive out of the computer.
Flip the computer over and open the screen.
Start from a corner and run the plastic opening tools along the edge of the back cover.
After the cover has been completely loosened around the entire perimeter, close the screen and flip the computer over.
Gently pry back the cover starting from the middle, bottom edge.
Using the Phillips #1 screwdriver, remove the three 8.0 mm screws holding the battery in place.
Remove the battery by tilting the top of the battery towards you and pulling the battery away from the mounting tabs.
crwdns2935229:08crwdne2935229:0
Where to find, buy the same battery.
Divya Lekha - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Where r living. We can help you which website you buy this battery
Mahima Singh - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Thank you for the guide! =D
Kevin - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
If you are living in Delhi ncr. We provide him service and delivery of hp ht03xl battery at very reasonable price at your office and home. Our home service executive will help you to assemble this battery. Nice description details about here. How to replace hp original battery.
Not clear what battery to buy for my HP Laptop Model 15-da0012dx and where are places to buy. Please advise, thank you for this service and your help
Geo - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
