HP 15-da0002dx Battery Replacement
  1. HP 15-da0002dx Battery Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure the computer is completely turned off.
    Your instructions worked perfectly. My machine had a 1 TB sata drive 5400 rpm and I replaced it with a Kingston ssd and cloned it prior to installing. Works perfectly.
    The rubber feet on the computer cracked but was able to stick them back on. May need to be glued if they come off. Thank You, Irwin
    Irwin - crwdns2934203:0crwdne2934203:0
  2. HP 15-da0002dx Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn over the laptop.
    • The HP label should be touching the table and the bottom cover should be facing up.
  3. HP 15-da0002dx Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-da0002dx Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Two plastic feet are located on adjacent sides of the back cover.
    • Peel back the plastic feet using the plastic opening tools.
    thanks for posting this writeup. something to take not of, is the rubber strippings (feet) are of two different sizes
    - the thicker rubber strip goes on the back side
    - the thinner rubber strip goes on/towards the front
    chrisrjones1983 - crwdns2934203:0crwdne2934203:0
  4. HP 15-da0002dx Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the Phillips #1 screwdriver, unscrew the eleven 9.0 mm screws holding the back cover in place.
  5. HP 15-da0002dx Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully flip over the computer so the HP label is now facing the ceiling.
    need to Remove the CD rom drive prior to prying the two halves apart. If all the screws are removed from step 2 it should just slide out.
    ElectroDad - crwdns2934203:0crwdne2934203:0
  6. HP 15-da0002dx Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-da0002dx Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Open the screen.
    • Run the plastic opening tools along the edge of the back cover. Do this until the back cover becomes loose.
  7. HP 15-da0002dx Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Close the screen and flip over the laptop. Using the plastic opening tools, gently take off the back cover starting from the middle, bottom edge.
  8. HP 15-da0002dx Battery Replacement, Battery: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screws holding the battery in place using a Phillips #1 screwdriver.
    I put my m.2 but i didn't remove the battery before and when I opened my laptop the m.2 wasn't showed on (my computer)
    Ali Hamdi - crwdns2934203:0crwdne2934203:0
  9. HP 15-da0002dx Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-da0002dx Battery Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using your fingers, tilt the top part of the battery towards you.
    • Continue to pull the rest of the battery away from the mounting tabs to remove.
crwdns2935229:05crwdne2935229:0
Abigail Aron
crwdns2935283:009/04/19crwdne2935283:0
1,124 crwdns2915208:0crwdne2915208:0
University of Alabama, Team S2-G8, Bedsole Fall 2019 crwdns2935289:0University of Alabama, Team S2-G8, Bedsole Fall 2019crwdne2935289:0
UA-BEDSOLE-F19S2G8
Where to find, buy the same battery spare???
Divya Lekha - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 37
crwdns2942667:0crwdne2942667:0 4,558
