Here is a step by step way to remove and replace your battery for the HP 15-bs168cl. Please make sure that you have tested the battery following the instructions listed here.
If your battery fails the tests and needs to be replaced, you are able to purchase a new battery and replace it following this guide.
Unplug your laptop from its power adapter.
Turn the laptop over.
Slide the Battery lock slider to the right until you see the “Unlocked” lock symbol.
Slide the Battery release slider towards the battery while pulling the battery out.
