HP 15-bs051od Screen Replacement
    1. HP 15-bs051od Screen Replacement, RAM: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Start with the laptop face down.
      • Remove the eight 6 mm Phillips head screws securing the lower case.
    2. HP 15-bs051od Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-bs051od Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the opening tool to pry the lower case away from the body of the laptop.
      • Remove the lower case.
    3. HP 15-bs051od Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 15-bs051od Screen Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 15-bs051od Screen Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Pull the RAM-retaining arms away from the RAM chip.
      • The RAM chip should slightly "pop" up from it's socket.
    4. HP 15-bs051od Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-bs051od Screen Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pull the RAM chip out of its socket.
      • Our device does not specifically have a second RAM chip, but make sure to remove the second RAM chip below the first RAM chip.
      • Repeat this process for the second RAM chip.
    1. HP 15-bs051od Screen Replacement, Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 15-bs051od Screen Replacement, Motherboard: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 15-bs051od Screen Replacement, Motherboard: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the four (4 mm) Phillips screws on the heatsink.
      • Remove the exhaust by carefully lifting it up.
    2. HP 15-bs051od Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Disconnect the connecting cable of the fan and remove the fan.
    3. HP 15-bs051od Screen Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-bs051od Screen Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pull the red, white, black, and blue cable directly out of its port.
    4. HP 15-bs051od Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Slide the left speaker out.
    5. HP 15-bs051od Screen Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pull the black and red cable connecting both speakers out of its secure fastening.
    6. HP 15-bs051od Screen Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pull the right speaker out by sliding from left to right.
    7. HP 15-bs051od Screen Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-bs051od Screen Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Locate the motherboard.
      • The motherboard is the biggest blue-colored surface located inside the computer.
      • Locate the six ribbon cables.
    8. HP 15-bs051od Screen Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-bs051od Screen Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Flip up the ZIF lock bars that keep the six ribbon cables in place.
      • Slide the rest of the ribbon cables out of their fastenings.
    9. HP 15-bs051od Screen Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-bs051od Screen Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the four (4 mm) Phillips screws securing the motherboard.
    10. HP 15-bs051od Screen Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-bs051od Screen Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the single (4 mm) Phillips screw on the Wi-Fi card.
      • Slide the Wi-Fi card out of its port.
    11. HP 15-bs051od Screen Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-bs051od Screen Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Unfasten the connecting cable.
    12. HP 15-bs051od Screen Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-bs051od Screen Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the display cable.
    13. HP 15-bs051od Screen Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift up the motherboard.
    1. HP 15-bs051od Screen Replacement, Screen: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the following Phillips screws:
      • Five 7 mm screws on the display hinge.
      • One 3 mm screw.
    2. HP 15-bs051od Screen Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Partially open the laptop and remove the base.
    3. HP 15-bs051od Screen Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-bs051od Screen Replacement: crwdns2935265:020crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the opening tool to carefully separate the screen cover from the screen.
      • Use the opening tool to carefully remove the adhesive screen bezel from around the screen.
    4. HP 15-bs051od Screen Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Two 4 mm screws from the top of the screen.
      • Two 4 mm from the bottom of the screen.
    5. HP 15-bs051od Screen Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Carefully lift the screen from the display assembly without disconnecting the display cable.
    6. HP 15-bs051od Screen Replacement: crwdns2935265:023crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the display cable from the back of the screen.
    7. HP 15-bs051od Screen Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the screen from the display assembly.
Kaz Furtado
crwdns2935283:003/20/23crwdne2935283:0
148 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 6-1, Botvin Spring 2023 crwdns2935289:0UMass Dartmouth, Team 6-1, Botvin Spring 2023crwdne2935289:0
UMASSD-BOTVIN-S23S6G1
crwdns2942667:0crwdne2942667:0 520
