HP 15-bs051od Motherboard Replacement
  1. HP 15-bs051od Motherboard Replacement, RAM: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Start with the laptop face down.
    • Remove the eight 6 mm Phillips head screws securing the lower case.
  2. HP 15-bs051od Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-bs051od Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the opening tool to pry the lower case away from the body of the laptop.
    • Remove the lower case.
  3. HP 15-bs051od Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 15-bs051od Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 15-bs051od Motherboard Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the RAM-retaining arms away from the RAM chip.
    • The RAM chip should slightly "pop" up from it's socket.
  4. HP 15-bs051od Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-bs051od Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the RAM chip out of its socket.
    • Our device does not specifically have a second RAM chip, but make sure to remove the second RAM chip below the first RAM chip.
    • Repeat this process for the second RAM chip.
  5. HP 15-bs051od Motherboard Replacement, Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 15-bs051od Motherboard Replacement, Motherboard: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 15-bs051od Motherboard Replacement, Motherboard: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four (4 mm) Phillips screws on the heatsink.
    • Remove the exhaust by carefully lifting it up.
  6. HP 15-bs051od Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the connecting cable of the fan and remove the fan.
  7. HP 15-bs051od Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-bs051od Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the red, white, black, and blue cable directly out of its port.
  8. HP 15-bs051od Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the left speaker out.
  9. HP 15-bs051od Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the black and red cable connecting both speakers out of its secure fastening.
  10. HP 15-bs051od Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the right speaker out by sliding from left to right.
  11. HP 15-bs051od Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-bs051od Motherboard Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the motherboard.
    • The motherboard is the biggest blue-colored surface located inside the computer.
    • Locate the six ribbon cables.
  12. HP 15-bs051od Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-bs051od Motherboard Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip up the ZIF lock bars that keep the six ribbon cables in place.
    • Slide the rest of the ribbon cables out of their fastenings.
  13. HP 15-bs051od Motherboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-bs051od Motherboard Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four (4 mm) Phillips screws securing the motherboard.
  14. HP 15-bs051od Motherboard Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-bs051od Motherboard Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the single (4 mm) Phillips screw on the Wi-Fi card.
    • Slide the Wi-Fi card out of its port.
  15. HP 15-bs051od Motherboard Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-bs051od Motherboard Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unfasten the connecting cable.
  16. HP 15-bs051od Motherboard Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-bs051od Motherboard Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the display cable.
  17. HP 15-bs051od Motherboard Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up the motherboard.
Jessica Walia
crwdns2935283:003/20/23crwdne2935283:0
589 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 6-1, Botvin Spring 2023 crwdns2935289:0UMass Dartmouth, Team 6-1, Botvin Spring 2023crwdne2935289:0
UMASSD-BOTVIN-S23S6G1
crwdns2942667:0crwdne2942667:0 400
