I teach you how to open the laptop to access and change the RAM, hard drive or whatever you need.
crwdns2936621:0crwdne2936621:0
Put the laptop facing down
Move the left battery safe lock to the right
Slide the right battery safe lock to the left
This lock is harder than the previous, with this the battery should pop-up.
Use a Philips 0 screwdriver
Use a straw to take off just enough of the rubber feet of the 4 corners
Use a Phillips screwdriver 0
Replace each rubber foot in place after removing the screws
You will have a total of 10 screws
It will go out easily with or without a straw
You can check the model number
Flip the laptop and open it
Use a plastic tool or a straw to separate the pieces of the chassis
Flip the laptop and separate the inferior cover of the chassis
Hard Drive 2.5" SATA
2 RAM memory slots type DDR4 SO-DIMM
CPU Intel 7th generation
Active heat sink (fan)
Wireless card
Watch battery, 3V. CR2030
crwdns2935229:046crwdne2935229:0
crwdns2934873:0crwdne2934873:0
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
crwdns2947412:021crwdne2947412:0
Se me rompio las bisagras … como se reemplazan ?
No tengo la laptop a mano para tomarle fotos, aunque en el paso 7 se puede ver algo. Depende de la rotura, lo típico que se rompe es la rosca para los tornillos, hay que crear un nueva rosca con material adicional, sin embargo, desconozco el procedimiento. En todo caso, puedes contactarme a mis RRSS que están en mi perfil de ifixit.
Your step by step guide is apt. Thanks
Perebowei Titus Otoru Nigeria
Buenas podrías hacer un tutorial desarmando y ensamblando la webcam
Saludos, ya entregué la laptop al cliente.
