HP 15-ay114cy Fan Replacement
    1. HP 15-ay114cy Fan Replacement, Orient the Laptop: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Orient the Laptop so the HP logo is facing the table and the battery tabs are accessible.
      • Ensure the laptop is powered off before moving forward.
    2. HP 15-ay114cy Fan Replacement, Push out the Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-ay114cy Fan Replacement, Push out the Battery: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Place your index fingers on each of the two battery holder clips.
      • Using your index fingers, push the battery holder clips inwards (towards the center of the laptop).
    3. HP 15-ay114cy Fan Replacement, Remove the Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-ay114cy Fan Replacement, Remove the Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • After the battery clips are pushed in, use either hand to grab hold of the battery.
      • Gently push up to remove the battery.
    1. HP 15-ay114cy Fan Replacement, Unscrew the Back Cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-ay114cy Fan Replacement, Unscrew the Back Cover: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a Phillips #0 screwdriver to remove the twelve 8 mm Phillips screws that are holding down the bottom cover of the laptop.
    2. HP 15-ay114cy Fan Replacement, Remove the Disk Drive: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-ay114cy Fan Replacement, Remove the Disk Drive: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Grab a hold of the disk drive and carefully pull it away from the computer.
      • Continue to slide the disk drive out of the laptop until fully removed.
      • Due to the removal of the battery, no power is available to open the disk drive through the use of the eject button.
      • Make sure to pull out the disk drive at a 90 degree angle as demonstrated. Do not attempt to wiggle the drive out of the laptop.
      • There will be resistance when removing the drive. Mishandling may cause broken wires, which could make your disk drive inoperative.
    3. HP 15-ay114cy Fan Replacement, Remove the Back Cover: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 15-ay114cy Fan Replacement, Remove the Back Cover: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 15-ay114cy Fan Replacement, Remove the Back Cover: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Place a plastic opening tool in-between the upper and lower pieces of the bottom cover.
      • Using your hands and the plastic opening tool, gently separate the cover from the frame.
      • Slowly remove the bottom cover from the base of the laptop.
      • Using metal pry tools can damage your device.
    4. HP 15-ay114cy Fan Replacement, Remove the Fan Screws: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-ay114cy Fan Replacement, Remove the Fan Screws: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a Phillips #0 screwdriver to remove the two 8 mm Phillips-head screws that attach the fan to the base.
    5. HP 15-ay114cy Fan Replacement, Remove the Fan Wire: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 15-ay114cy Fan Replacement, Remove the Fan Wire: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 15-ay114cy Fan Replacement, Remove the Fan Wire: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Using your index finger and thumb, carefully grab the wire that connects the fan to the motherboard.
      • Using a bit of force, remove the cable from the connector on the motherboard.
    6. HP 15-ay114cy Fan Replacement, Remove the Fan: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-ay114cy Fan Replacement, Remove the Fan: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using your hand, grab one of the fan corners and pull up.
      • Carefully remove the entire fan from the base of the laptop.
Bradley Evans
crwdns2935283:001/24/20crwdne2935283:0
622 crwdns2915208:0crwdne2915208:0
S20S3G#1 crwdns2935289:0S20S3G#1crwdne2935289:0
Local Repair Groups
crwdns2935297:066crwdne2935297:0
crwdns2936753:030crwdne2936753:0 45
crwdns2942667:0crwdne2942667:0 1,328
