HP 15-ay052nr USB Port Replacement
    1. HP 15-ay052nr USB Port Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • To protect the device and yourself, make sure your device is completely powered down before disassembling. Disconnect all external devices before starting any tear down process.
      • Turn the device and lay it upside-down on a flat surface so the base of the computer is facing upwards.
    2. HP 15-ay052nr USB Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Identify the two (2) sliding lock mechanisms on either side of the battery and slide them towards the center.
      • The sliders are located at the back of the device on the side where the display hinges are.
      • The slider closest to the optical drive (CD reader) clicks open but the opposite slider has a spring.
    3. HP 15-ay052nr USB Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pull the battery slightly up and out to remove.
      • If the battery doesn't pop out, the sliders weren't pushed in far enough. Push the sliders towards the center until the battery pops out.
    1. HP 15-ay052nr USB Port Replacement, Bottom Cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the rubber feet on the bottom of the device to access all the screws.
      • There are two rubber feet, one on each side of the battery compartment.
    2. HP 15-ay052nr USB Port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Unscrew the twelve 9 mm JIS #0 screws on the back of the device.
      • Gently remove the optical drive (CD reader) to more easily separate the base.
    3. HP 15-ay052nr USB Port Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Unclip the keyboard surface from the base using an iFixit opening tool around the entire border.
    4. HP 15-ay052nr USB Port Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Separate the base of the computer from the component assembly.
      • The optical drive can be placed in the base where it corresponds to prevent misplacing it.
    1. HP 15-ay052nr USB Port Replacement, USB Port: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the three 3mm JIS #0 screws from the hard drive.
    2. HP 15-ay052nr USB Port Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Unplug the hard drive and set aside.
    3. HP 15-ay052nr USB Port Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Disconnect the cable that is attached to the motherboard from the USB board.
      • The motherboard can be identified as the big blue board in the opposite side of the USB board we are replacing.
    4. HP 15-ay052nr USB Port Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the single 3mm JIS #0 screw.
      • Once the screw is out, the USB board can be pulled out for replacement.
Morgan Distler
crwdns2935283:001/10/19crwdne2935283:0
914 crwdns2915208:0crwdne2915208:0
Oregon Institute of Technology, Team S1-G5, Lancaster Winter 2019 crwdns2935289:0Oregon Institute of Technology, Team S1-G5, Lancaster Winter 2019crwdne2935289:0
OIT-LANCASTER-W19S1G5
crwdns2935297:071crwdne2935297:0
crwdns2942667:0crwdne2942667:0 668
