HP 15-ay052nr Keyboard and Touchpad Replacement
  1. HP 15-ay052nr Keyboard and Touchpad Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To protect the device and yourself, make sure your device is completely powered down before disassembling. Disconnect all external devices before starting any tear down process.
    • Turn the device and lay it upside-down on a flat surface so the base of the computer is facing upwards.
  2. HP 15-ay052nr Keyboard and Touchpad Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Identify the two (2) sliding lock mechanisms on either side of the battery and slide them towards the center.
    • The sliders are located at the back of the device on the side where the display hinges are.
    • The slider closest to the optical drive (CD reader) clicks open but the opposite slider has a spring.
  3. HP 15-ay052nr Keyboard and Touchpad Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the battery slightly up and out to remove.
    • If the battery doesn't pop out, the sliders weren't pushed in far enough. Push the sliders towards the center until the battery pops out.
  4. HP 15-ay052nr Keyboard and Touchpad Replacement, Bottom Cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the rubber feet on the bottom of the device to access all the screws.
    • There are two rubber feet, one on each side of the battery compartment.
  5. HP 15-ay052nr Keyboard and Touchpad Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the twelve 9 mm JIS #0 screws on the back of the device.
    • Gently remove the optical drive (CD reader) to more easily separate the base.
  6. HP 15-ay052nr Keyboard and Touchpad Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unclip the keyboard surface from the base using an iFixit opening tool around the entire border.
  7. HP 15-ay052nr Keyboard and Touchpad Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the base of the computer from the component assembly.
    • The optical drive can be placed in the base where it corresponds to prevent misplacing it.
  8. HP 15-ay052nr Keyboard and Touchpad Replacement, Fan: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 6.5 mm JIS #0 screws holding the cooling fan to the base.
    • The base is the side by the heatsink, which is made of copper.
  9. HP 15-ay052nr Keyboard and Touchpad Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the fan cable from the motherboard.
    • The fan can now be removed.
  10. HP 15-ay052nr Keyboard and Touchpad Replacement, Motherboard: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the three 3 mm JIS #0 screws from the hard drive.
  11. HP 15-ay052nr Keyboard and Touchpad Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the hard drive from the motherboard.
  12. HP 15-ay052nr Keyboard and Touchpad Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug display from the motherboard.
    • The connection is under a sealing sticker; peel up the sticker to unplug the connection.
  13. HP 15-ay052nr Keyboard and Touchpad Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the power port from the motherboard.
  14. HP 15-ay052nr Keyboard and Touchpad Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the display wire from the wireless adapter.
  15. HP 15-ay052nr Keyboard and Touchpad Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the single screw from the wireless card and gently remove the drive.
  16. HP 15-ay052nr Keyboard and Touchpad Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the keyboard from the motherboard.
  17. HP 15-ay052nr Keyboard and Touchpad Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the optical drive connection from the motherboard.
  18. HP 15-ay052nr Keyboard and Touchpad Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the memory chip from the motherboard by pushing the clips away from the chip.
    • The chip will pop out once the clips are pulled far enough apart.
    • This is to access the touch-pad wires.
  19. HP 15-ay052nr Keyboard and Touchpad Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug both (2) wires for the touch-pad from the motherboard.
  20. HP 15-ay052nr Keyboard and Touchpad Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the speakers from the motherboard.
  21. HP 15-ay052nr Keyboard and Touchpad Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the power button from the motherboard.
  22. HP 15-ay052nr Keyboard and Touchpad Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the four 3mm JIS #0 screws that secure the motherboard.
    • Once all the screws are removed, the motherboard can be removed by simply lifting it up.
  23. HP 15-ay052nr Keyboard and Touchpad Replacement, Keyboard and Touchpad: crwdns2935265:023crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 3mm JIS #0 screws that secure the touchpad board.
  24. HP 15-ay052nr Keyboard and Touchpad Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-ay052nr Keyboard and Touchpad Replacement: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the display by unscrewing the four 3mm JIS #0 screws.
    • Remove one 2mm JIS #0 screw.
  25. HP 15-ay052nr Keyboard and Touchpad Replacement: crwdns2935265:025crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the power port from its cradle.
  26. HP 15-ay052nr Keyboard and Touchpad Replacement: crwdns2935265:026crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the one 3mm JIS #0 screw holding the power button board to the device.
  27. HP 15-ay052nr Keyboard and Touchpad Replacement: crwdns2935265:027crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-ay052nr Keyboard and Touchpad Replacement: crwdns2935265:027crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the two 3mm JIS #0 screws that hold the optical drive (CD-reader) connection to the device.
  28. HP 15-ay052nr Keyboard and Touchpad Replacement: crwdns2935265:028crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-ay052nr Keyboard and Touchpad Replacement: crwdns2935265:028crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two (2) speakers located on the botten edge of the keyboard cover.
    • Along the edge that the touch-pad board and hard drive is located.
  29. HP 15-ay052nr Keyboard and Touchpad Replacement: crwdns2935265:029crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure there is nothing else attached to the keyboard cover so all that remains is the keyboard and touch-pad.
Morgan Distler
crwdns2935283:001/10/19crwdne2935283:0
914 crwdns2915208:0crwdne2915208:0
Oregon Institute of Technology, Team S1-G5, Lancaster Winter 2019 crwdns2935289:0Oregon Institute of Technology, Team S1-G5, Lancaster Winter 2019crwdne2935289:0
OIT-LANCASTER-W19S1G5
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 673
