HP 15-ay052nr Fan Replacement
  1. HP 15-ay052nr Fan Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To protect the device and yourself, make sure your device is completely powered down before disassembling. Disconnect all external devices before starting any tear down process.
    • Turn the device and lay it upside-down on a flat surface so the base of the computer is facing upwards.
  2. HP 15-ay052nr Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Identify the two (2) sliding lock mechanisms on either side of the battery and slide them towards the center.
    • The sliders are located at the back of the device on the side where the display hinges are.
    • The slider closest to the optical drive (CD reader) clicks open but the opposite slider has a spring.
  3. HP 15-ay052nr Fan Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the battery slightly up and out to remove.
    • If the battery doesn't pop out, the sliders weren't pushed in far enough. Push the sliders towards the center until the battery pops out.
  4. HP 15-ay052nr Fan Replacement, Bottom Cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the rubber feet on the bottom of the device to access all the screws.
    • There are two rubber feet, one on each side of the battery compartment.
  5. HP 15-ay052nr Fan Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the twelve 9 mm JIS #0 screws on the back of the device.
    • Gently remove the optical drive (CD reader) to more easily separate the base.
  6. HP 15-ay052nr Fan Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unclip the keyboard surface from the base using an iFixit opening tool around the entire border.
  7. HP 15-ay052nr Fan Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the base of the computer from the component assembly.
    • The optical drive can be placed in the base where it corresponds to prevent misplacing it.
  8. HP 15-ay052nr Fan Replacement, Fan: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 6.5 mm JIS #0 screws holding the cooling fan to the base.
    • The base is the side by the heatsink, which is made of copper.
  9. HP 15-ay052nr Fan Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the fan cable from the motherboard.
    • The fan can now be removed.
Stephanie Harms
crwdns2935283:001/13/19crwdne2935283:0
97 crwdns2915208:0crwdne2915208:0
Oregon Institute of Technology, Team S1-G5, Lancaster Winter 2019 crwdns2935289:0Oregon Institute of Technology, Team S1-G5, Lancaster Winter 2019crwdne2935289:0
OIT-LANCASTER-W19S1G5
crwdns2942667:0crwdne2942667:0 541
