Use this guide to replace a broken fan that is showing signs of overheating, loud whirring noises, or odd smells.
Turn the device and lay it upside-down on a flat surface so the base of the computer is facing upwards.
Identify the two (2) sliding lock mechanisms on either side of the battery and slide them towards the center.
Pull the battery slightly up and out to remove.
Remove the rubber feet on the bottom of the device to access all the screws.
Unscrew the twelve 9 mm JIS #0 screws on the back of the device.
Gently remove the optical drive (CD reader) to more easily separate the base.
Unclip the keyboard surface from the base using an iFixit opening tool around the entire border.
Separate the base of the computer from the component assembly.
Remove the two 6.5 mm JIS #0 screws holding the cooling fan to the base.
Unplug the fan cable from the motherboard.
