HP 15-af013cl Hard Drive Replacement
  1. HP 15-af013cl Hard Drive Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Start off by flipping the laptop on its back.
  2. HP 15-af013cl Hard Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 15-af013cl Hard Drive Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 15-af013cl Hard Drive Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push the two spring-loaded tabs inward.
    • Once unlatched, pull the battery out of its compartment.
  3. HP 15-af013cl Hard Drive Replacement, Hard Drive: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the Phillips P0 screwdriver, remove the 9 M2.5mm x 6.5mm screws from the bottom of the laptop.
    • Remove the additional 2 M2.0mm × 1.5mm Phillips screws located in the battery compartment.
  4. HP 15-af013cl Hard Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-af013cl Hard Drive Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the optical disk drive from the side of the laptop.
  5. HP 15-af013cl Hard Drive Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-af013cl Hard Drive Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift off the bottom cover, exposing the motherboard and other components underneath.
    • Unscrew the four Phillips 3.0mm x 3.5mm screws on the hard drive bracket using the PH0 screwdriver.
  6. HP 15-af013cl Hard Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-af013cl Hard Drive Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently lift the hard drive from its position on the inside of the laptop.
    • Disconnect the ribbon cable from the hard drive.
Stephen Perreira
crwdns2935283:009/27/17crwdne2935283:0
787 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S8-G6, Banghart Fall 2017 crwdns2935289:0Cal Poly, Team S8-G6, Banghart Fall 2017crwdne2935289:0
CPSU-BANGHART-F17S8G6
crwdns2942667:0crwdne2942667:0 1,415
