HP 15-af013cl Front Facing Camera Replacement
  1. HP 15-af013cl Front Facing Camera Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Start off by flipping the laptop on its back.
  2. HP 15-af013cl Front Facing Camera Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 15-af013cl Front Facing Camera Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 15-af013cl Front Facing Camera Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push the two spring-loaded tabs inward.
    • Once unlatched, pull the battery out of its compartment.
  3. HP 15-af013cl Front Facing Camera Replacement, Screen: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the laptop over and have it open as you normally would.
  4. HP 15-af013cl Front Facing Camera Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 15-af013cl Front Facing Camera Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 15-af013cl Front Facing Camera Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a pry tool, unclip the entire outer plastic cover from the front of the screen.
    • Gently remove the front plastic cover.
  5. HP 15-af013cl Front Facing Camera Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 2.5mm × 3.0mm Phillips screws from each corner of the display.
  6. HP 15-af013cl Front Facing Camera Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-af013cl Front Facing Camera Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully lift the display out of the laptop shell and flip it on its front.
    • Disconnect the single cable from the back of the display.
  7. HP 15-af013cl Front Facing Camera Replacement, Front Facing Camera: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-af013cl Front Facing Camera Replacement, Front Facing Camera: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The front camera is held in by light adhesive. Pry gently on the back of the camera in order to remove it.
    • Remove the cable from under the metal foil.
  8. HP 15-af013cl Front Facing Camera Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the laptop back over.
    • Using the Phillips P0 screwdriver, remove the 9 M2.5mm x 6.5mm screws from the bottom of the laptop.
    • Remove the additional 2 M2.0mm × 1.5mm Phillips screws located in the battery compartment.
  9. HP 15-af013cl Front Facing Camera Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-af013cl Front Facing Camera Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the optical disk drive from the side of the laptop.
  10. HP 15-af013cl Front Facing Camera Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift off the bottom cover, exposing the motherboard and other components underneath.
  11. HP 15-af013cl Front Facing Camera Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the display ribbon cable from the motherboard.
Stephen Perreira
crwdns2935283:009/27/17crwdne2935283:0
787 crwdns2915208:0crwdne2915208:0
Cal Poly, Team S8-G6, Banghart Fall 2017 crwdns2935289:0Cal Poly, Team S8-G6, Banghart Fall 2017crwdne2935289:0
CPSU-BANGHART-F17S8G6
crwdns2942667:0crwdne2942667:0 539
