HP 15-R263DX RAM Replacement
  1. HP 15-R263DX RAM Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-R263DX RAM Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Eject the battery from the computer by sliding the two clips on the bottom of the computer toward the center of the computer.
    • Slide the battery out as shown in the picture.
  2. HP 15-R263DX RAM Replacement, Optical Drive: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-R263DX RAM Replacement, Optical Drive: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a Phillips #1 screwdriver, remove the small screw next to the disc engraving shown in the picture.
  3. HP 15-R263DX RAM Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently slide the optical drive out of the side of the computer.
  4. HP 15-R263DX RAM Replacement, HP 15-R263DX Disassembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-R263DX RAM Replacement, HP 15-R263DX Disassembly: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the two corner grips on the hinge side of the computer.
    • Using a metal spudger, remove the two corner grips to reveal the screws.
  5. HP 15-R263DX RAM Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 11 small screws on the bottom of the computer that are shown in the picture.
  6. HP 15-R263DX RAM Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 2 small screws that are on the bottom side of the disc tray slot.
    • These screws are shorter and wider than the others.
  7. HP 15-R263DX RAM Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-R263DX RAM Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once the keyboard is loose, do not immediately pull away from computer. It is attached by the ribbon connector.
    • Using a spudger, pry around the edges of the keyboard until all clips are disengaged and the keyboard is loose from the computer.
    • To disconnect the ribbon connector, flip up the black clip shown in the picture.
    • Gently pull the ribbon until disconnected.
    Does not show how to get to memory or hard drive.
    Moto X - crwdns2934203:0crwdne2934203:0
  8. HP 15-R263DX RAM Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-R263DX RAM Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the other two ribbon connectors underneath the keyboard by fliping up the black clips.
    • Remove the 4 small screws shown in the picture.
  9. HP 15-R263DX RAM Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disengage the face plate clips by prying the case away from around the outer edge of the face plate with a metal wedge.
    • The face plate can then be lifted away from the computer.
  10. HP 15-R263DX RAM Replacement, Hard Drive: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 2 black screws holding the hard drive to the computer frame.
  11. HP 15-R263DX RAM Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-R263DX RAM Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently slide the hard drive away from the motherboard to disconnect it.
    • After it's disconnected, lift the hard drive up to remove it from the computer.
  12. HP 15-R263DX RAM Replacement, RAM: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 2 screws holding the motherboard into the case of the laptop.
  13. HP 15-R263DX RAM Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-R263DX RAM Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the connections around the motherboard.
    • There is a connection hidden underneath the board. Remove this one last as you will need to lift the motherboard up to access it.
  14. HP 15-R263DX RAM Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-R263DX RAM Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the screw holding the WiFi chip in place.
    • Slide the chip away from the motherboard and set it elsewhere inside the computer.
  15. HP 15-R263DX RAM Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the motherboard over to access the underside revealing the RAM.
  16. HP 15-R263DX RAM Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-R263DX RAM Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the RAM chip by simultaneously prying the 2 spring clips away from the RAM.
    • The RAM will pop up when both clips are completely released.
crwdns2935229:05crwdne2935229:0
Drake Hort
crwdns2935283:003/05/18crwdne2935283:0
487 crwdns2915208:0crwdne2915208:0
Washington State, Team S2-G3, Lobnitz Spring 2018 crwdns2935289:0Washington State, Team S2-G3, Lobnitz Spring 2018crwdne2935289:0
WSU-LOBNITZ-S18S2G3
crwdns2931471:08crwdne2931471:0
is this laptop model ram upgradable?
Gordon Velupillai - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 1,499
