HP 15-R263DX Hard Drive Replacement
    1. HP 15-R263DX Hard Drive Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-R263DX Hard Drive Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Eject the battery from the computer by sliding the two clips on the bottom of the computer toward the center of the computer.
      • Slide the battery out as shown in the picture.
    1. HP 15-R263DX Hard Drive Replacement, Optical Drive: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-R263DX Hard Drive Replacement, Optical Drive: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using a Phillips #1 screwdriver, remove the small screw next to the disc engraving shown in the picture.
    2. HP 15-R263DX Hard Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Gently slide the optical drive out of the side of the computer.
    1. HP 15-R263DX Hard Drive Replacement, HP 15-R263DX Disassembly: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-R263DX Hard Drive Replacement, HP 15-R263DX Disassembly: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Locate the two corner grips on the hinge side of the computer.
      • Using a metal spudger, remove the two corner grips to reveal the screws.
    2. HP 15-R263DX Hard Drive Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the 11 small screws on the bottom of the computer that are shown in the picture.
    3. HP 15-R263DX Hard Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the 2 small screws that are on the bottom side of the disc tray slot.
      • These screws are shorter and wider than the others.
    4. HP 15-R263DX Hard Drive Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-R263DX Hard Drive Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Once the keyboard is loose, do not immediately pull away from computer. It is attached by the ribbon connector.
      • Using a spudger, pry around the edges of the keyboard until all clips are disengaged and the keyboard is loose from the computer.
      • To disconnect the ribbon connector, flip up the black clip shown in the picture.
      • Gently pull the ribbon until disconnected.
    5. HP 15-R263DX Hard Drive Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-R263DX Hard Drive Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Disconnect the other two ribbon connectors underneath the keyboard by fliping up the black clips.
      • Remove the 4 small screws shown in the picture.
    6. HP 15-R263DX Hard Drive Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Disengage the face plate clips by prying the case away from around the outer edge of the face plate with a metal wedge.
      • The face plate can then be lifted away from the computer.
    1. HP 15-R263DX Hard Drive Replacement, Hard Drive: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the 2 black screws holding the hard drive to the computer frame.
    2. HP 15-R263DX Hard Drive Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 15-R263DX Hard Drive Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Gently slide the hard drive away from the motherboard to disconnect it.
      • After it's disconnected, lift the hard drive up to remove it from the computer.
Drake Hort
crwdns2935283:003/05/18crwdne2935283:0
487 crwdns2915208:0crwdne2915208:0
Washington State, Team S2-G3, Lobnitz Spring 2018 crwdns2935289:0Washington State, Team S2-G3, Lobnitz Spring 2018crwdne2935289:0
WSU-LOBNITZ-S18S2G3
crwdns2931471:08crwdne2931471:0
crwdns2942667:0crwdne2942667:0 1,919
