HP 14-dq0055dx Charging port Replacement
  1. HP 14-dq0055dx Charging port Replacement, Charging port: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 14-dq0055dx Charging port Replacement, Charging port: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 14-dq0055dx Charging port Replacement, Charging port: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn laptop upside down exposing the screws.
    • Gently remove the rubber grips to reveal the remaining screws.
    • Using a Phillips head #1 screwdriver, remove all eight 2.5 mm screws.
  2. HP 14-dq0055dx Charging port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the laptop back over and open the screen.
    • Insert an opening tool into the seam between the keyboard and the bottom panel.
    • Run the opening tool along the seam to separate the back panel from the keyboard.
    • You may hear clicking as clips release the bottom panel from the keyboard.
  3. HP 14-dq0055dx Charging port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 14-dq0055dx Charging port Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After the bottom panel has been separated from the laptop, close the laptop.
    • Flip the laptop back over.
    • Carefully place hands on either side of the laptop's back panel.
    • Lift up to remove the panel.
  4. HP 14-dq0055dx Charging port Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 14-dq0055dx Charging port Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 14-dq0055dx Charging port Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a Phillips #1 screwdriver remove the four 2.5 mm screws securing the battery in place.
    • To remove the battery, lift the battery slightly toward the bottom.
    • Pull the battery toward you.
    • Do not pull the battery straight up after the removal of the screws.
  5. HP 14-dq0055dx Charging port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 14-dq0055dx Charging port Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 14-dq0055dx Charging port Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the charging port bracket at the top left of the laptop.
    • Remove the two 2.5 mm screws that secure the charging port bracket.
    • Flip the bracket up and away from you.
  6. HP 14-dq0055dx Charging port Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the wires connected to the charging port.
    • Carefully pull the white tab out of its socket.
Guy Medina
crwdns2935283:002/01/24crwdne2935283:0
491 crwdns2915208:0crwdne2915208:0
Gateway, Team 8-88, Gonzalez Spring 2024 crwdns2935289:0Gateway, Team 8-88, Gonzalez Spring 2024crwdne2935289:0
GCC-GONZALEZ-S24S8G88
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 200
