HP 14-cf2112wm Back Cover Replacement
  1. HP 14-cf2112wm Back Cover Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before you begin, shut down your laptop and disconnect all cables.
    • Turn the laptop over so the bottom case is facing up.
  2. HP 14-cf2112wm Back Cover Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 14-cf2112wm Back Cover Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to pry under the end of the screw cover.
    • When the edge is lifted up, use your fingers to pull the rest of the strip off.
    • Try to keep the strip intact so you can replace it at reassembly.
  3. HP 14-cf2112wm Back Cover Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 14-cf2112wm Back Cover Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove six 6 mm screws from the back case.
  4. HP 14-cf2112wm Back Cover Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 14-cf2112wm Back Cover Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 14-cf2112wm Back Cover Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a pick or opening tool to pry along the edges of the back cover from the keyboard side of the laptop.
    • Be careful as the case edges are sharp.
  5. HP 14-cf2112wm Back Cover Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the back cover off the laptop.
To reassemble your device, follow these instructions backwards.
Shishi Hu
crwdns2935283:003/18/24crwdne2935283:0
763 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 1-2, Konn Spring 2024 crwdns2935289:0UMass Dartmouth, Team 1-2, Konn Spring 2024crwdne2935289:0
UMASSD-KONN-S24S1G2
it will not power up or charge
larry - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 78
crwdns2942667:0crwdne2942667:0 932
