HP 14-an012nr Daughterboard Replacement
  1. HP 14-an012nr Daughterboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 14-an012nr Daughterboard Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 14-an012nr Daughterboard Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the battery by sliding both sliders inward.
  2. HP 14-an012nr Daughterboard Replacement, Back Panel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 14-an012nr Daughterboard Replacement, Back Panel: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 14-an012nr Daughterboard Replacement, Back Panel: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the eight 6 mm screws from the back panel using a Phillips #1 screwdriver.
    • Remove the rubber pads from the upper corners of the laptop to reveal two screws on each side.
    • Remove six 4 mm screws using a Phillips #1 screwdriver.
    • Pry the back panel off using an opening tool, working your way around the edges.
  3. HP 14-an012nr Daughterboard Replacement, Daughterboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 14-an012nr Daughterboard Replacement, Daughterboard: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 14-an012nr Daughterboard Replacement, Daughterboard: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the three 4 mm screws holding the daughterboard down using a Phillips #00 screwdriver.
    • Remove the ribbon cable by gently pressing on the blue tab and pulling on the plastic reinforcement at the end of the cable.
    • Be careful when removing the cable as pulling with too much force can damage both the cable and connector.
    • Remove the daughterboard.
Mihikou Ouaogninlin
crwdns2935283:010/24/23crwdne2935283:0
91 crwdns2915208:0crwdne2915208:0
Gateway, Team 2-2, Gonzalez Fall 2023 crwdns2935289:0Gateway, Team 2-2, Gonzalez Fall 2023crwdne2935289:0
GCC-GONZALEZ-F23S2G2
crwdns2942667:0crwdne2942667:0 295
