HP 14-am052nr RAM Replacement
  1. HP 14-am052nr RAM Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HP 14-am052nr RAM Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HP 14-am052nr RAM Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the laptop over to its bottom so that the backside is facing you.
    • Using your fingers, push the two locking tabs inwards to release the battery.
    • Remove the battery from the device.
  2. HP 14-am052nr RAM Replacement, Back Panel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 14-am052nr RAM Replacement, Back Panel: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After removing the battery with the laptop on its back, expose screws that are hidden under the rubber feet and the center label.
    • Using the Phillips #0 screwdriver, remove fourteen (14) 6 mm screws from the back panel.
  3. HP 14-am052nr RAM Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 14-am052nr RAM Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a prying tool to remove the back panel from the base of the computer.
  4. HP 14-am052nr RAM Replacement, RAM: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push the two silver tabs on the sides of the RAM away from each other.
    • The RAM should now be loose and pointed upwards.
  5. HP 14-am052nr RAM Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift and remove the RAM stick at a 45 degree angle from the laptop.
Matthew Heather
crwdns2935283:011/03/21crwdne2935283:0
379 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 3-3, Sinclaire Fall 2021 crwdns2935289:0UMass Dartmouth, Team 3-3, Sinclaire Fall 2021crwdne2935289:0
UMASSD-SINCLAIRE-F21S3G3
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 353
