HP 10 2101 Camera Replacement
crwdns2869540:0crwdne2869540:0: 605
2
16
70
605
crwdns2959984:0crwdne2959984:0: 0
crwdns2959956:0crwdne2959956:0
crwdns2955944:0crwdne2955944:0: 10 - 20 crwdns2931279:0crwdne2931279:0
crwdns2955970:0crwdne2955970:0: crwdns2937803:0crwdne2937803:0
The cameras are directly attached to the motherboard through web cam cables. In order to access those cables to remove the cameras, the battery must be removed first. This guide also requires unsoldering the battery connections from the motherboard.
    1. HP 10 2101 Camera Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Identify the SD card port.
    2. HP 10 2101 Camera Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Insert the smallest plastic opening tool into the SD card port. Gently pry until the back panel separates from the screen panel.
      • Do not insert opening tool too far. Avoid making contact with the metal inside the port.
    3. HP 10 2101 Camera Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Slide the opening tool along the seam between the back panel and the screen panel, prying the panels apart as you move around the edges.
    4. HP 10 2101 Camera Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Separate the back panel from the rest of the device.
    1. HP 10 2101 Camera Replacement, Battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Desolder the battery connectors from the motherboard.
    2. HP 10 2101 Camera Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pull the bright blue-green tabs to remove the battery from the rest of the device.
      • Pulling the tabs may not fully disconnect the battery from the metal display casing.
    3. HP 10 2101 Camera Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HP 10 2101 Camera Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • If the previous step is unsuccessful, wedge the smallest plastic opening tool between the adhesive and the metal display casing.
      • Wedging may apply unsafe pressure on the battery. Be careful not to puncture the battery.
    1. HP 10 2101 Camera Replacement, Camera: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Peel off the metal mesh tape with the plastic opening tool.
    2. HP 10 2101 Camera Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Disconnect the zero insertion force (ZIF) cable. Use the tip of the spudger or your fingernail to flip up the small white locking flap. Then, you can safely pull the cable out.
      • Repeat this process for the second connection port.
      • Be sure to pry up on the hinged flap, not the connector socket.
    3. HP 10 2101 Camera Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the front and back camera.
Bryce Harmsen
crwdns2935283:009/25/18crwdne2935283:0
692 crwdns2915208:0crwdne2915208:0
Central Washington University, Team S1-G4, Pengilly Fall 2018 crwdns2935289:0Central Washington University, Team S1-G4, Pengilly Fall 2018crwdne2935289:0
CWU-PENGILLY-F18S1G4
crwdns2936753:030crwdne2936753:0 70
crwdns2959996:0crwdne2959996:0 605
