HMDX Jam Plus Micro USB Jack Replacement
  1. HMDX Jam Plus  Micro USB Jack Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HMDX Jam Plus  Micro USB Jack Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HMDX Jam Plus  Micro USB Jack Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the device over so the bottom is facing up.
    • Use the large plastic opening tool to gently pry the rubber base from the device.
    • Slowly move the plastic opening tool around the edge of the rubber base to separate it from the plastic.
  2. HMDX Jam Plus  Micro USB Jack Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HMDX Jam Plus  Micro USB Jack Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove the four black 9mm screws from the device.
  3. HMDX Jam Plus  Micro USB Jack Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HMDX Jam Plus  Micro USB Jack Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently separate the base from the rest of the device to reveal the battery and the main board.
  4. HMDX Jam Plus  Micro USB Jack Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HMDX Jam Plus  Micro USB Jack Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HMDX Jam Plus  Micro USB Jack Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully use the plastic opening tool to remove the glue around the battery and speaker connectors.
    • Pull gently on the connectors to separate each one from the main board.
    • The battery is connected to board in the red socket and the speaker is connected in the white socket.
  5. HMDX Jam Plus  Micro USB Jack Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HMDX Jam Plus  Micro USB Jack Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HMDX Jam Plus  Micro USB Jack Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Batteries can be very dangerous if punctured. Use extra caution when using tools around the battery.
    • Use the plastic opening tool to gently pry the battery free from the rest of the device.
  6. HMDX Jam Plus  Micro USB Jack Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HMDX Jam Plus  Micro USB Jack Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use new adhesive to secure battery back to the rest of the device.
  7. HMDX Jam Plus  Micro USB Jack Replacement, Micro USB Jack: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HMDX Jam Plus  Micro USB Jack Replacement, Micro USB Jack: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three black 6mm screws from the main board using a Philips #00 screwdriver.
  8. HMDX Jam Plus  Micro USB Jack Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HMDX Jam Plus  Micro USB Jack Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully lift the main board away from the plastic.
    • Lift the side with the buttons first and be careful not to damage the Line In Jack or the Micro USB Jack.
  9. HMDX Jam Plus  Micro USB Jack Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the Micro soldering iron to heat up each pad and use the desoldering wick to wick up the melted solder.
    • The surface mount jack should pull from the surface without much force. Use tweezers to apply upward pressure on on the jack.
    • Do not apply too much heat to the board as it may damage other portions of the board.
Maxwell Erickson
crwdns2935283:010/22/15crwdne2935283:0
587 crwdns2915208:0crwdne2915208:0
Montana Tech, Team 10-3, Shirk Fall 2015 crwdns2935289:0Montana Tech, Team 10-3, Shirk Fall 2015crwdne2935289:0
MTUM-SHIRK-F15S10G3
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 819
