This guide provides steps for replacing a damaged Line In Jack on the HMDX Jam Plus. This guide requires previous soldering skill and utilizes a Micro Soldering Iron. This guide is should not be attempted by beginners. If performed incorrectly the device may not function anymore.
Flip the device over so the bottom is facing up.
Use the large plastic opening tool to gently pry the rubber base from the device.
Slowly move the plastic opening tool around the edge of the rubber base to separate it from the plastic.
Use a Phillips #1 screwdriver to remove the four black 9mm screws from the device.
Gently separate the base from the rest of the device to reveal the battery and the main board.
Carefully use the plastic opening tool to remove the glue around the battery and speaker connectors.
Pull gently on the connectors to separate each one from the main board.
Use the plastic opening tool to gently pry the battery free from the rest of the device.
Remove the three black 6mm screws from the main board using a Philips #00 screwdriver.
Carefully lift the main board away from the plastic.
Lift the side with the buttons first and be careful not to damage the Line In Jack or the Micro USB Jack.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use the Micro soldering iron to heat up each pad and use the desoldering wick to wick up the melted solder.
The surface mount jack should pull from the surface without much force. Use tweezers to apply upward pressure on on the jack.
