HMDX Chill Charging Port Replacement
  1. HMDX Chill Charging Port Replacement, Remove Rubber Base: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HMDX Chill Charging Port Replacement, Remove Rubber Base: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HMDX Chill Charging Port Replacement, Remove Rubber Base: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a metal spudger under the rubber base.
    • Pry the rubber base off.
  2. HMDX Chill Charging Port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove four 9 mm screws from the base of the device.
  3. HMDX Chill Charging Port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HMDX Chill Charging Port Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Grip the base of the HMDX Chill.
    • Pull the base upwards.
    I still need help here. Problem not fixed
    Lornejanes1@gmail.com
    Thank you
    Lorne Janes - crwdns2934203:0crwdne2934203:0
  4. HMDX Chill Charging Port Replacement, Motherboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HMDX Chill Charging Port Replacement, Motherboard: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HMDX Chill Charging Port Replacement, Motherboard: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove the four 6 mm screws that secure the motherboard to the base of the device.
  5. HMDX Chill Charging Port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the motherboard away from the base gently.
    • Do not pull too hard on the motherboard. It is still attached to the base by wires.
  6. HMDX Chill Charging Port Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HMDX Chill Charging Port Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HMDX Chill Charging Port Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a soldering iron to desolder the wires connecting the motherboard to the case.
  7. HMDX Chill Charging Port Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HMDX Chill Charging Port Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert the spudger between the case and the wire and move the spudger upwards.
    • This will cause the case to prop open.
    • The wire behind the motherboard will now be visible. Pull this out from behind.
  8. HMDX Chill Charging Port Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the soldering iron to desolder the wires connecting the motherboard to the base of the HMDX Chill.
  9. HMDX Chill Charging Port Replacement, Desolder the Charging Port: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HMDX Chill Charging Port Replacement, Desolder the Charging Port: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a soldering tool, desolder the charging port from the motherboard.
Jourdan Holubasch
crwdns2935283:003/31/16crwdne2935283:0
759 crwdns2915208:0crwdne2915208:0
EWU-Giguere-S16S1G1 crwdns2935289:0EWU-Giguere-S16S1G1crwdne2935289:0
Community
I have the charging port removed. Where do I find a replacement??
Aaron Hughes - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 530
