HKC P776A Motherboard Replacement
  1. HKC P776A Motherboard Replacement, Separating Digitizer and Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the plastic opening tool between the digitizer and the case.
    • Place the spudger in the gap created by the plastic opening tool to assist in separation.
  2. HKC P776A Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HKC P776A Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the spudger along the perimeter of the device to fully separate the two pieces.
  3. HKC P776A Motherboard Replacement, Separating the Screen and Digitizer: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HKC P776A Motherboard Replacement, Separating the Screen and Digitizer: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to pop the screen out from the digitizer.
  4. HKC P776A Motherboard Replacement, Removing the Optical Cord from the Motherbaord: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the plastic opening tool, lift the black latch up.
  5. HKC P776A Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the optical cord out from the motherboard.
  6. HKC P776A Motherboard Replacement, Separating the Screen and the Digitizer: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HKC P776A Motherboard Replacement, Separating the Screen and the Digitizer: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
  7. HKC P776A Motherboard Replacement, Removing the Cable from the Motherboard: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HKC P776A Motherboard Replacement, Removing the Cable from the Motherboard: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the tip of the spudger to release the latches on the motherboard.
  8. HKC P776A Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the cable from the motherboard.
  9. HKC P776A Motherboard Replacement, Removing the Cable from the Moatherboard: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HKC P776A Motherboard Replacement, Removing the Cable from the Moatherboard: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
  10. HKC P776A Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HKC P776A Motherboard Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the camera from the device.
  11. HKC P776A Motherboard Replacement, Wifi Antenna: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HKC P776A Motherboard Replacement, Wifi Antenna: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel off the tape that is attaching the wifi antenna to the case.
  12. HKC P776A Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the soldering iron, heat up the solder that is attaching the antenna to the motheboard.
    • The heat from the soldering iron may cause personal injury or damage the internal components of the tablet.
  13. HKC P776A Motherboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Desoldering Pump
    $3.99
    • Suck up the leftover solder using the desoldering pump.
    • Remove the wifi antenna from the motherboard.
  14. HKC P776A Motherboard Replacement, Battery: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the plastic opening tool between the battery and case.
    • Apply leverage to break the glue that is attaching the battery to the case.
  15. HKC P776A Motherboard Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Continue breaking the glue along the perimeter of the battery until the battery can be removed.
    • Breaking all the glue between the battery and case may take a long time.
  16. HKC P776A Motherboard Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HKC P776A Motherboard Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the soldering iron, heat up the solder that is attaching the battery to the motheboard.
  17. HKC P776A Motherboard Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery from the motherboard.
  18. HKC P776A Motherboard Replacement, Motherboard: crwdns2935265:018crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HKC P776A Motherboard Replacement, Motherboard: crwdns2935265:018crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HKC P776A Motherboard Replacement, Motherboard: crwdns2935265:018crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the screwdriver, remove the four 4mm by 1.5mm screws that are attaching the motherboard to the case.
  19. HKC P776A Motherboard Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HKC P776A Motherboard Replacement: crwdns2935265:019crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the black material that is covering the speaker.
  20. HKC P776A Motherboard Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the spudger into the speaker slot on the back of the case.
  21. HKC P776A Motherboard Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Push the speaker out of the case with the spudger.
  22. HKC P776A Motherboard Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the motherboard from the case.
Ryan Gornati
crwdns2935283:001/22/15crwdne2935283:0
409 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 7-6, Remmell Winter 2015 crwdns2935289:0USF Tampa, Team 7-6, Remmell Winter 2015crwdne2935289:0
USFT-REMMELL-W15S7G6
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 267
