HIFIMAN Sundara Headstrap Replacement
    • This step is necessarily destructive, and with careful application of the cutting pliers, no damage will be done to the headphones. Make sure to remove both fasteners.
    • The headstrap-headband interface is the piece of plastic which the headstrap itself adheres and whereby it attaches or interfaces with the headband. This part will be referred to as Interface for brevity from here on.
    DON'T CUT IT.
    from the inside of the headband, stick a flathead between the metal fastener and the plastic body, and pry downward carefully. the metal fastener should come free without breaking it.
    never perfect - crwdns2934203:0crwdne2934203:0
    It's soft, likely aluminum. How do you intend to do that without scratching those parts or bending them? I suppose someone could test heat application, but then you have to make sure you aren't doing something to the plastic as that could be bad obviously.
    Andrew -
    It's adhered with glue, the glue hardens with time it seems, mine naturally come off because I've had my pair for several years; maybe there is non-physical means of removing it?
    oh dear god - crwdns2934203:0crwdne2934203:0
    • Remove the old headstrap from the headband as shown by detaching the Interfaces from the headband.
    • A metal strip is present inside both of the Interfaces. Make sure to retrieve them and set them aside in a salient location.
    • Remove the drivers (speakers) as shown.
    Thanks for not describing how to actually get the headband off. No amount of prying or pulling has worked.
    Justin - crwdns2934203:0crwdne2934203:0
    Usually it's a good idea to follow a guide in-order as opposed to out-of-order. This will ensure all headbands are understood as to how to actually get the headband off via prying or pulling, possibly even excising as well.
    Andrew -
    Andrew, what do you mean? Following the guide in order does not magically provide the correct way to pry/pull the headband assembly apart. Neither your writing nor video explains what one needs to be done to take apart the plastic part. You only said "detach the interface" and showed a quick video of a prying motion.
    What need is there to assume that I followed the guide out-of-order?
    Justin -
    Was being a little facetious. The guide shows you need to remove the metal fasteners before you can remove the interfaces (which are fixed to the headstrap) out of their socket.
    Andrew -
    • Insert the new headstrap as shown into the headband by inserting the Interface into the headband, but do not yet press the Interface into the headband.
    • Don't forget to re-insert the metal strips mentioned in Step 2 here as shown in the video.
    so how does this go back together? very little text and the important part of the video is covered by a hand
    morally dubious - crwdns2934203:0crwdne2934203:0
    If iFixit allowed for better guide production, I could probably have provided additional images, but for some reason, videos and images are incompatible (at least at the time of making this guide). Unfortunately, I can't elaborate until I get home, and I don't know when that will be. It could be a week, or it could be a few months, as that's where my (broken) Sundara's are that are in need of repair.
    iFixit is great, but someone needs to fix this awful guide interface.
    Andrew -
    • As the design of the headband is ambipolar, which side of it is designated as the left or right side does not matter.
    • Before inserting the drivers back into the headband, make sure the metal place holders that secure driver length are correctly inserted at the start of the interface. The small spheroidal convex indentation of this piece should have the convex (protruding) side facing outwards which will interface with the concave indentations on the drivers.
    • To verify that the metal placeholders are properly installed: if the inner part of the Interface that attaches the headstrap to the headband can be closed with ease (must be actively held together), and the driver being inserted correctly locks in place, the metal place holders have been correctly installed and you may proceed onwards.
    • Make sure the metal fasteners have the correct polarity, either L or R, facing on the inside.
    • After ensuring that the metal fasteners are facing the correct direction, slide the drivers back into the headband and firmly press closed the Interface as shown in the video.
    • Firmly push the metal fastener upwards to permanently secure the Interface to the headstrap as shown. No adhesive is required.
    • Make sure to apply equal amounts of force as you push the fastener onto the Interface.
    This is absolute bullshit. The metal band can be easily removed without destroying it by cutting it. A simple ultra-thin straight edge with a pair of needle nose pliers can loosen the metal bands that make repairing the headband possible.
    dannonf - crwdns2934203:0crwdne2934203:0
    Why should that even matter? The metal bands get replaced anyways. Your comment is absolute nonsense.
    Andrew -
    Andrew strikes again... failing to consider the possibility that disassembly could be required without access to spare parts...
    Justin -
    Justin: this is a guide for replacing the headstrap. That necessarily assumes you have all the parts necessary to replace it, and you can't replace it if the headstrap can't be attached securely. Since I don't know of a way to ensure the fragile, metal bands get removed non-destructively without bending or scratching it (it's a very soft metal, probably aluminum as I said elsewhere), I'm not going to suggest that. Besides, who has the skill to do so given the scale of things being so small? Just find replacement parts somehow. No point in arguing about this. I really shouldn't have to explain what you can reason for yourself.
    Andrew -
Headstrap replacement is complete.
Andrew
crwdns2935283:010/22/21crwdne2935283:0
121 crwdns2915208:0crwdne2915208:0
crwdns2947412:014crwdne2947412:0
you absolutely do not need to cut the metal fastener in step 1. just pry it downward carefully with a flathead screwdriver and it comes free.
Thanks for this tip, had to deal with a loose headstrap and it is very easy to just pry it with a screwdriver. You don't even dent it at all if you're careful.
Tomáš Renner -
Where do you buy the headstrap?
Ryan Ferguson -
This assumes you can get past the heavy glue. The videos are from the factory itself apparently in my parts and repair request. Questionable use of copyrighted content, yes, but I had let them know, and they haven't done anything, so /shrug.
Andrew -
@ryanfergus24861 Simply contact HiFiMan themselves and request parts. That's what I did.
Andrew -
I opened them brand new and one side of the strap just fell out. I've tried doing what you did here, but I can't seem to get the one side to stay
Moki - crwdns2934203:0crwdne2934203:0
If by "one side of the strap just fell out" means "the strap is loose, but the metal fastener on the end is intact and in-place; and the plastic interface which it's normally attached to is thus likewise, then either it has been torn off, or (my guess if out of box) the piece wasn't glued, or the adhesive has been weakened such that one side of the strap came out.
You'll need to either: do what was suggested elsewhere here (manage to pry off the metal fastener where the strap fell out flawlessly [it's quite malleable and soft a metal]),
OR request replacement parts directly from HiFiMan (specifically the metal fasteners and a new strap just in case), then follow my instructions here as-is; and take a strong adhesive of your choice in which you are confident will not chemically corrode the plastic to which the strap will be permanently bonded with the plastic interface (as it should be). If there is insufficient material, then use a new strap (comes attached to the plastic interfaces). The latter is safer.
Andrew -
Has anyone here tried to undo the screws on the yokes? I want to change the headband for a different one, but those screws came really tight from the factory for some reason.
Yes - crwdns2934203:0crwdne2934203:0
If there's screws now, that's certainly better on Hifiman's part, but if so, then this guide is not applicable to this updated hardware. Suggest uploading an image of what you're talking about. In any case, you'll have to unscrew those at your own risk. Sometimes screws are screwed in with a sort of adhesive, or otherwise have something at the other end of the screw to keep it from falling out when unscrewed. It's a pain because if it's adhesive, depending on how much the designers and implementors cared, the force of torque may loosen the screw at the cost of damaging the product itself, but in my experience, I've never had that happen to me really; worst thing has usually been ripping threads off, either from the hole itself because it's hard metal on soft plastic, or vice versa.
Andrew -
Oh boy did they glue it! It's some loctite plus very low quality screw combo, only way to get it off in my case was to grind the screw-head inside until the outer end came off.
emaN -
Can confirm that the screws on the yokes do not come out. I spent hours trying to unscrew with pliers. I even removed the speakers from their respective housings and tried to see if there was some kind of double threading but nothing worked. Its ironic because the replacement headband i bought came with a full assembly including new yokes and screws but no way to unscrew the originals. Another issue with the replacement headstrap/headband was that the plastic clips that house the adjustment side of the yokes would not pop in and out like they were supposed to. It was apparent that they were factory adhered but that specific part was not the case on my original headband. Pretty disappointing and i bought the replacement 2 years ago for 15 bucks, now they sell the replacment for 125 dollars. I am not exaggerating it might be worth it to go for a simple DIY and really improve the ease of future headstrap replacements.
Ryan Ferguson - crwdns2934203:0crwdne2934203:0
Unfortunate. It sounds to me like there must be some variation in your particular HIFIMAN Sundara headset compared to mine that I featured in this. I don't recall screws ever. If by yokes is meant the same thing as the metal fasteners as I called them, then that's an improvement actually, but not applicable to this guide however.
Andrew -
The yokes are the two metal pieces that secure the drivers/housing. They slide up and down to adjust the size of the headphones. On each yoke, there are two silver colored screws or rivets that hold attach the driver housing to the yokes.
No, this particular piece of advice is not tied to your method of replacement but considering this guide comes up as one of the top results for "hifiman sundara headband replacement" and your method was somewhat brute force oriented, i figured i would add some helpful advice to someone who went out and purchased the actual oem replacement piece like i did.
The entire sundara setup is modular and can be taken apart/put back together minus these screws on the yokes and the headstrap itself. Thats why people are saying there is no reason to cut them off like you did.
The headstrap is adhered to the plastic clips that connect the headband and yokes, once this adhesive breaks down over time or becomes too weak to hold you basically need to reglue it at that point.
Ryan Ferguson -
Oh I see. Thank you. Is there by any chance maybe an encyclopedia or dictionary of engineering terms perhaps that you (or if anyone else wants to chime in) know of?
Andrew -
crwdns2936753:07crwdne2936753:0 69
crwdns2936753:030crwdne2936753:0 418
crwdns2942667:0crwdne2942667:0 9,605
