HAY Sowden Toaster – won't turn off
  1. HAY Sowden Toaster – won't turn off, Opening the housing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HAY Sowden Toaster – won't turn off, Opening the housing: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HAY Sowden Toaster – won't turn off, Opening the housing: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully pull the handle in the direction of the arrow.
    • Unscrew the 4 screws (triangular).
    • Bend away the 4 clips.
  2. HAY Sowden Toaster – won't turn off: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 HAY Sowden Toaster – won't turn off: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the circuit board
    • and disconnect the magnet and power supply.
  3. HAY Sowden Toaster – won't turn off, Replace the capacitor: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 HAY Sowden Toaster – won't turn off, Replace the capacitor: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 HAY Sowden Toaster – won't turn off, Replace the capacitor: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Replace capacitor C1 25 V, 220 µF.
    I dont know. It was not my toaster and i have no better pictures. Are you sure that the ic is broken? What´s your problem with your toaster?
    https://dertoaster.org/toasterreparatur....
    Perhaps it is the 8a2511, but I am not sure. Please check the connetcions first. You can get this ic from a lot of toasters with 3 buttons. Look for an broken toaster with 3 buttons at the e-waste.
    Andreas Reheis -
    I'm sure it's short circuited but the IC has the serials erased.
    Fernando Dos reis - crwdns2934203:0crwdne2934203:0
Follow the steps in reverse order to reassemble your device.
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934883:0oldturkey03crwdne2934883:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
Andreas Reheis
crwdns2935283:003/19/17crwdne2935283:0
2.732 crwdns2915208:0crwdne2915208:0
crwdns2935297:020crwdne2935297:0
erfindergarden foundation crwdns2935289:0erfindergarden foundationcrwdne2935289:0
Local Repair Groups
crwdns2931471:06crwdne2931471:0
crwdns2935297:057crwdne2935297:0
crwdns2947412:05crwdne2947412:0
Thanks for this information! I have the same toaster and need to replace the diodes listed at D1. Can you advise what values are required?
Angus - crwdns2934203:0crwdne2934203:0
Hi Angus,
it is an 1N4007 Diode. But I think that de IC is also broken when the diode ist broken. The AC could destroy the IC.
Look at this datasheed and the typical electrical use in a toaster. https://www.digikey.ca/en/htmldatasheets...
good luck and give me a feedback. www.dertoaster.org
Andreas Reheis -
Hi Andreas: I replaced the 1N4007 diode and the toaster worked for about 5 seconds before the capacitor blew! Any idea what's up?
Hi Angus, okay, just an idea!
The heatingwire is shortet > the voltage on the board is to high > First check the resistenc of the heatingwire an calculate the watt. Compare it with value of the producer writen on the toaster. Then check the AC 12V on the board. Be careful!!!
Perhaps you can go to an Repair-Cafe in your town.
Andreas Reheis -
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 343
