H4D: MAP Sensor Cleaning
  1. H4D: MAP Sensor Cleaning, Accessing the engine hood: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the trunk.
    • Put aside the trunk carpets.
  2. H4D: MAP Sensor Cleaning, Acessing the engine compartment: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the 6 T50 screws by hand or using a wrench and a socket.
    • Lift and put aside the engine hood.
  3. H4D: MAP Sensor Cleaning, Pressure Sensor Removal: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 H4D: MAP Sensor Cleaning, Pressure Sensor Removal: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the pressure sensor connector.
    • Gently remove the pressure sensor by pulling it upwards. The sensor must be rotated in a specific way to be removed.
    • The sensor is difficult to extract, even with slim fingers. Those with thicker fingers may not be able to perform this operation without using a tool.
    • Breaking the MAP sensor during removal would require removing the intake manifold, which is a complex procedure.
    • Gently spray contact cleaner in short bursts into the pressure sensor's orifice.
    • Shake the sensor, allow the liquid to drain out, and repeat the process several times.
    • Let the sensor dry for a few minutes.
    • Certain products, or simply repeated cleaning combined with wear, will eventually lead to the inevitable replacement of the MAP sensor.
    • Bosch Motorsports recommends:
    • Lubricating the seals with a drop of engine oil (e.g., 5W40).
    • Avoid using silicone-based lubricants or grease.
    • Insert the pressure sensor into its position until it is fully seated.
    • Reconnect the pressure sensor connector.
Congratulations! You've just cleaned your intake pressure sensor!
crwdns2934873:0crwdne2934873:0
fr en
100%
crwdns2934883:0João Pedro Dominguescrwdne2934883:0 crwdns2934875:0crwdne2934875:0
crwdns2934877:0crwdne2934877:0 ›
AntonioTwingo
crwdns2935283:008/24/22crwdne2935283:0
7,448 crwdns2915208:0crwdne2915208:0
crwdns2935297:045crwdne2935297:0
Attention , cette intervention a l’air facile à faire donc je me suis dit pourquoi pas …
En retirant le capteur, la tétine tenue par deux joints c’est cassé à l’intérieur du collecteur d’admission d’air 🤦‍♂️pourtant j’y suis allé doucement !
J’ai aussitôt commandé un nouveau capteur m.a.p
J’ai dû démonter le collecteur d’admission d’air pour retirer ce gros bout de plastique qui se baladait dedans car il risquait de finir dans une soupape et de faire de gros dégâts…
Pour démonter le collecteur d’admission d’air j’ai dû démonter :
Tuyau de boîte à air,boîtier papillon,rampe d’injection,pot d’échappement, catalyseur, tuyaux de liquide de refroidissement, câble électrique, mettre la voiture sur chandelles de chaque côté pour pouvoir dévisser les deux boulons de Silent bloc moteur et faire descendre le moteur de 20 cm environ à l’aide d’un cric car c’est la seul façon de retirer ce collecteur d’air
La voiture n’a pas roulé 1 semaines le temps que le nouveau capteur m.a.p arrive.
Donc faite attention !
Philippe - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 37
crwdns2936753:030crwdne2936753:0 157
crwdns2942667:0crwdne2942667:0 3,534
