Grip Tape Application
  1. Grip Tape Application, Grip Tape Application: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Peel off the paper backing from the sheet of grip tape.
    • Make sure you do not fold or wrinkle the grip tape.
  2. Grip Tape Application: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Center the sheet of grip tape evenly over the top of the skateboard deck.
  3. Grip Tape Application: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Grip Tape Application: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Starting from the very middle and moving outward, firmly press down on the grip tape while smoothing out any air bubbles that start to form.
  4. Grip Tape Application: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Grip Tape Application: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a screwdriver to scrape along the edges of the skateboard. This will remove some of the grip around the edges making the trimming process easier on you and your equipment.
    • You can use the utility knife to cut a perpendicular line in the excess grip tape if it is resisting the screwdriver too much.
  5. Grip Tape Application: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Grip Tape Application: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Grip Tape Application: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a utility knife to begin cutting around the edge of your skateboard to remove excess grip tape.
    • Angle your knife towards the inside of the skateboard to make it easier to cut a straight line.
    • Be careful when using the utility knife and always keep it pointed away from yourself and others.
  6. Grip Tape Application: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once you have removed all of the excess grip tape, you can use the scraps to sand the edges of your cut to smooth out any small inconsistencies.
    • Use caution when sanding as the grip tape can become heated.
  7. Grip Tape Application: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If air bubbles persist, gently use a utility knife to poke a small hole in the grip tape at the center of the bubble and press out the air.
  8. Grip Tape Application: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Grip Tape Application: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After you have finished applying your grip tape, you can use a small screwdriver to poke holes where your truck hardware will be installed.
The next logical step in the assembly of a skateboard is to install skateboard trucks, please reference the Truck Installation guide.
Jared Stine
crwdns2935283:010/05/12crwdne2935283:0
800 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 6-32, Regan Fall 2012 crwdns2935289:0Cal Poly, Team 6-32, Regan Fall 2012crwdne2935289:0
CPSU-REGAN-F12S6G32
crwdns2942667:0crwdne2942667:0 8,045
