Greenworks Pro 80V Battery Charger Cooling Fan Replacement
  1. Greenworks Pro 80V Battery Charger Cooling Fan Replacement, Remove rubber feet and screws: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Greenworks Pro 80V Battery Charger Cooling Fan Replacement, Remove rubber feet and screws: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Greenworks Pro 80V Battery Charger Cooling Fan Replacement, Remove rubber feet and screws: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The feet can be difficult to remove at times as they are made with very stiff rubber. A metal pry tool or wide flat-head screwdriver is helpful
    • The screws have a T20 Torx head on them. All 4 screws are identical
  2. Greenworks Pro 80V Battery Charger Cooling Fan Replacement, Open case: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Greenworks Pro 80V Battery Charger Cooling Fan Replacement, Open case: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Greenworks Pro 80V Battery Charger Cooling Fan Replacement, Open case: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the green top of the unit, starting at the long side away from the plug
    • After opening half-way you will need to disconnect the top LED from the board
    • Once fully open you should see the two existing fans connected to the board
    • This is a good opportunity to blow out any cobwebs or debris in the charger
  3. Greenworks Pro 80V Battery Charger Cooling Fan Replacement, Remove and replace the blower fan: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Greenworks Pro 80V Battery Charger Cooling Fan Replacement, Remove and replace the blower fan: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Greenworks Pro 80V Battery Charger Cooling Fan Replacement, Remove and replace the blower fan: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the single T15H screw holding the fan
    • To remove the fan, pivot it counterclockwise to disconnect it from the housing and then lift it off the pin on the bottom left
    • The blower fan is connected to the right 2-pin connector labeled JB
  4. Greenworks Pro 80V Battery Charger Cooling Fan Replacement, Remove and replace the case fan: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Greenworks Pro 80V Battery Charger Cooling Fan Replacement, Remove and replace the case fan: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Greenworks Pro 80V Battery Charger Cooling Fan Replacement, Remove and replace the case fan: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The case fan does not have any screws holding it in place
    • The case fan connects to the left 2-pin power connector labelled JA
  5. Greenworks Pro 80V Battery Charger Cooling Fan Replacement, Reassemble: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reassembly is the reverse of disassembly
    • Tuck any excess fan wire to the left side of the board, ensuring it won't interfere with the case fan
    • Don't forget to re-connect the 3-pin LED cable to the board during reassembly
Reassembly is the reverse of disassembly.
loredous
crwdns2935283:003/30/23crwdne2935283:0
366 crwdns2915208:0crwdne2915208:0
Thank you for this guide! I have the Greenworks GCH8020 80V low profile slow charger.  The fan started making squawking noises, and not turning properly.  I needed a CRV-T10 security bit to take out the 4 screws, no rubber feet to peel.  The top shell comes off, no wires to detach.  There was a bit of errant capacitor adhesive I need to pry off before the shell came cleanly off, no big deal.  The fan in it is a Younglin Tech co., LTD dc brushless fan DFS402012H 12vdc 1.6w (0.133amps) 2 pin.  I used this Youtube guide to re-lubricate the fan: https://www.youtube.com/watch?v=uOBAszlt... I unplugged it, used 2 blue generic computer pry tools to push the fan blade hub off.  Used the tools to pry off the white retainer ring. Removed the rotor (with commutator segments), basically a tube with metal bands. Cleaned those things with Isopropyl Alcohol.  Added a drop of sewing machine oil into the end of the rotor. Reassembled, and shazam!  A working fan again.
ziggy90127 - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 69
crwdns2942667:0crwdne2942667:0 1,256
