GravityLight LED Replacement
crwdns2869540:0crwdne2869540:0: 1,2 тыс.
2
17
88
1 231
crwdns2959984:0crwdne2959984:0: 0
crwdns2959956:0crwdne2959956:0
crwdns2955944:0crwdne2955944:0: 10 - 20 crwdns2931279:0crwdne2931279:0
crwdns2955970:0crwdne2955970:0: crwdns2937803:0crwdne2937803:0
If the white LED light will not turn on, then you will have to open up the device and replace the LED.
    1. GravityLight LED Replacement, Removing the Front Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GravityLight LED Replacement, Removing the Front Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Flip the GravityLight on its back and place it on a sturdy surface.
      • Unscrew the three 2cm Phillips #00 screws on the back of the GravityLight’s body.
    2. GravityLight LED Replacement, Opening the Device Housing: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Some of the internal pieces may loosen or fall out during disassembly.
      • Firmly grasp both parts of the GravityLight body and pull them apart.
    1. GravityLight LED Replacement, Removing the Back Panel Screws: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Place the back panel, the larger of the two pieces, on a sturdy surface with its back down.
      • Unscrew the two 2cm Phillips 00 screws on the inside of the back panel.
    2. GravityLight LED Replacement, Removing the LED Housing: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GravityLight LED Replacement, Removing the LED Housing: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Hold the LED housing in your hand, but do not separate it too far otherwise you will tear the wires.
      • Lift the LED housing away from the back panel.
    3. GravityLight LED Replacement, Remove the White Gear from the LED Housing: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GravityLight LED Replacement, Remove the White Gear from the LED Housing: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Grab the outside of the large, white gear in the LED housing and pull the gear out of the housing.
    4. GravityLight LED Replacement, Position the LED Housing: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Set the LED housing flat on a sturdy surface so that the back of the LED and the wires are exposed.
    5. GravityLight LED Replacement, Cut the Wires: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Place the GravityLight's back panel aside.
      • Use the Flush Wire Cutter to cut both the purple wire and the red wire that connect to the LED.
    6. GravityLight LED Replacement, Bend the LED Leads: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Take tweezers and bend the leads (the silver wires coming out of the bulb) so that the leads are straight.
      • The straight leads will make the LED easier to take out.
    7. GravityLight LED Replacement, Remove the LED: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Flip the LED housing over.
      • Pull the LED out with tweezers.
    8. GravityLight LED Replacement, Soldering the New LED: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • For reassembly: Flip the LED housing back over.
      • Put the new LED in its spot. Solder the red wire and the purple wire back onto the new leads.
      • Make sure that you pair each wire to the correct lead. If the LED still does not light, switch the wires on the leads.
      • For information on how to solder look here: How To Solder and Desolder Connections
Brian Gouldsberry
crwdns2935283:009/26/14crwdne2935283:0
201 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 12-2, Forte Fall 2014 crwdns2935289:0Cal Poly, Team 12-2, Forte Fall 2014crwdne2935289:0
CPSU-FORTE-F14S12G2
crwdns2935297:084crwdne2935297:0
crwdns2936753:030crwdne2936753:0 88
crwdns2959996:0crwdne2959996:0 1,231
