GravityLight Internal Gears Replacement
  1. GravityLight Internal Gears Replacement, Removing the Front Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GravityLight Internal Gears Replacement, Removing the Front Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the GravityLight on its back and place it on a sturdy surface.
    • Unscrew the three 2cm Phillips #00 screws on the back of the GravityLight’s body.
  2. GravityLight Internal Gears Replacement, Opening the Device Housing: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Some of the internal pieces may loosen or fall out during disassembly.
    • Firmly grasp both parts of the GravityLight body and pull them apart.
  3. GravityLight Internal Gears Replacement, Isolating the Back Panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take the thicker of the two parts, the back piece, and place it face down on a sturdy surface.
  4. GravityLight Internal Gears Replacement, Removing the Back Panel Screws: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Place the back panel, the larger of the two pieces, on a sturdy surface with its back down.
    • Unscrew the two 2cm Phillips 00 screws on the inside of the back panel.
  5. GravityLight Internal Gears Replacement, Removing the LED Housing: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Watch out for the wires! Keep them attached for this entire guide, or the GravityLight will not work!
    • Gently lift off the LED housing (the white disk).
    • Set the LED housing on the table next to the body of the device.
  6. GravityLight Internal Gears Replacement, Removing White Frame and Gear: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift off the white piece with four arms.
    • Lift off the black-rimmed gear.
    • Set both pieces aside in a safe place.
  7. GravityLight Internal Gears Replacement, Removing Internal Gears: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 GravityLight Internal Gears Replacement, Removing Internal Gears: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift off the three 3.5cm diameter gears.
    • Replace any stripped gears.
Michallynn Hoffman
crwdns2935283:009/26/14crwdne2935283:0
317 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 12-2, Forte Fall 2014 crwdns2935289:0Cal Poly, Team 12-2, Forte Fall 2014crwdne2935289:0
CPSU-FORTE-F14S12G2
Where can we find the replacement gears?
fb - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 3,157
