If the dial is stuck, then you will need to take the GravityLight apart to replace the dial. Also, you should replace the dial if you can turn it and the brightness does not change.
Flip the GravityLight on its back and place it on a sturdy surface.
Unscrew the three 2cm Phillips #00 screws on the back of the GravityLight’s body.
Firmly grasp both parts of the GravityLight body and pull them apart.
Take the thinner of the two parts, the front piece, and place it face down on a sturdy surface.
Use two hands to push the dial tabs inward, towards the center of the dial.
Push the tabs downward and through to the other side of the casing.
Flip the front panel over.
Fully remove the dial by pulling it out from the front.
