Graco Secure Coverage LED Nursery Unit Replacement
  1. Graco Secure Coverage LED Nursery Unit Replacement, Nursery Unit Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Graco Secure Coverage LED Nursery Unit Replacement, Nursery Unit Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Graco Secure Coverage LED Nursery Unit Replacement, Nursery Unit Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 9mm screw from the battery cover of the nursery unit using a Phillips #1 tip screwdriver.
  2. Graco Secure Coverage LED Nursery Unit Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Graco Secure Coverage LED Nursery Unit Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the plastic opening tool, pry and remove the battery cover carefully.
    • Remove the batteries using plastic opening tool.
    • Replace the batteries.
  3. Graco Secure Coverage LED Nursery Unit Replacement, LED Nursery Unit: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Graco Secure Coverage LED Nursery Unit Replacement, LED Nursery Unit: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 9mm Phillips #1 screws from the rare case of the device.
    • Place the screws in a secure place.
  4. Graco Secure Coverage LED Nursery Unit Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Hold the bottom of the device with one hand and pull down to separate the front and rare cases.
    • While holding the device with one hand, use plastic opening tool to pry the edges of the front case away from the back case.
    • Apply constant force carefully to avoid breaking any other plastic parts from the device.
  5. Graco Secure Coverage LED Nursery Unit Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Graco Secure Coverage LED Nursery Unit Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove all three 7mm Phillips #1 screws from the mother board.
    • Place the screws in secure place.
  6. Graco Secure Coverage LED Nursery Unit Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Graco Secure Coverage LED Nursery Unit Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Graco Secure Coverage LED Nursery Unit Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip over the motherboard to look at the LED pins that are connected to it.
    • Solder off the LED pin from the motherboard.
    • There are many pins are connect to the motherboard, so make sure that you solder off the LED pin.
    • Replace the LED.
Bryson Wolff
crwdns2935283:008/31/15crwdne2935283:0
237 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 6-5, Remmell Fall 2015 crwdns2935289:0USF Tampa, Team 6-5, Remmell Fall 2015crwdne2935289:0
USFT-REMMELL-F15S6G5
crwdns2942667:0crwdne2942667:0 328
