Graco Secure Coverage Nursery Unit Power Jack Replacement
  1. Graco Secure Coverage  Nursery Unit Power Jack Replacement, Nursery Unit Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Graco Secure Coverage  Nursery Unit Power Jack Replacement, Nursery Unit Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Graco Secure Coverage  Nursery Unit Power Jack Replacement, Nursery Unit Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the 9mm screw from the battery cover of the nursery unit using a Phillips #1 tip screwdriver.
  2. Graco Secure Coverage  Nursery Unit Power Jack Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Graco Secure Coverage  Nursery Unit Power Jack Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the plastic opening tool, pry and remove the battery cover carefully.
    • Remove the batteries using plastic opening tool.
    • Replace the batteries.
  3. Graco Secure Coverage  Nursery Unit Power Jack Replacement, Nursery Unit Power Jack: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Graco Secure Coverage  Nursery Unit Power Jack Replacement, Nursery Unit Power Jack: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 9mm Phillips #1 screws from the rare case of the device.
    • Place the screws in a secure place.
  4. Graco Secure Coverage  Nursery Unit Power Jack Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Hold the bottom of the device with one hand and pull down to separate the front and rare cases.
    • While holding the device with one hand, use plastic opening tool to pry the edges of the front case away from the back case.
    • Take your time and apply constant force carefully to avoid breaking any other plastic parts from the device.
  5. Graco Secure Coverage  Nursery Unit Power Jack Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Graco Secure Coverage  Nursery Unit Power Jack Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove all three 7mm Phillips #1 screws from the mother board.
    • Make sure you gently unscrew the screws with moderate force and light pressure to avoid any damages.
  6. Graco Secure Coverage  Nursery Unit Power Jack Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Graco Secure Coverage  Nursery Unit Power Jack Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pick up the mother board carefully.
    • Using plastic opening tool, gently pry the power jack plastic part and separate it away from the device case.
    • Apply constant force to avoid breaking the plastic part.
  7. Graco Secure Coverage  Nursery Unit Power Jack Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Solder off the wires from the mother board.
    • There are many pins attached to the mother board, make sure you solder off the proper pins that attached to the power jack wires.
    • Replace the power jack.
Omar Abdullah
crwdns2935283:009/06/15crwdne2935283:0
201 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 6-5, Remmell Fall 2015 crwdns2935289:0USF Tampa, Team 6-5, Remmell Fall 2015crwdne2935289:0
USFT-REMMELL-F15S6G5
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 251
