This guide will help you replace the front wheels. A small metal tool is required to remove the wheels. A key or screwdriver will work.
Flip the stroller over so that the wheels are facing upward.
Pull the sleeve covering the base of the wheel back from the wheels to expose the small metal button.
Use a key or other thin object to push down the button holding the wheel in place.
