Grace Digital Mondo Display Cover Replacement
  1. Grace Digital Mondo Display Cover Replacement, Front Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove (2) screws (14 mm) with a PH1 screwdriver on the device.
    • There is one screw on the back left, and another just below it on the bottom of the device.
  2. Grace Digital Mondo Display Cover Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Grace Digital Mondo Display Cover Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic spudger to remove the front preset selection buttons.
    • We recommend you remove all of them for easier access.
    • Gently reach underneath and pull off the mesh speaker cover. It only clips in so don't worry about breaking anything.
  3. Grace Digital Mondo Display Cover Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove (4) screws (14 mm) with a PH1 screwdriver on the front panel by the speaker.
    • Be careful with these screws, as they can be stripped easily.
  4. Grace Digital Mondo Display Cover Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Move the metal spudger around the front panel to remove any adhesive attaching the front panel to the device.
    • Pull apart the front panel from the device with help from the metal spudger.
  5. Grace Digital Mondo Display Cover Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Grace Digital Mondo Display Cover Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Grace Digital Mondo Display Cover Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Detach a pin connector at the top of the device using a metal spudger to open up the inner components.
    • Detach (4) pin connectors inside using a metal spudger to separate the front panel from the rest of the device.
  6. Grace Digital Mondo Display Cover Replacement, Display Cover: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove (10) screws (7 mm) with a PH1 screwdriver on the motherboard.
  7. Grace Digital Mondo Display Cover Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the display and motherboard from the front panel of the device.
    • Remove the display glass.
Nathaniel Brabham
crwdns2935283:002/08/16crwdne2935283:0
431 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 6-3, Eyestone Spring 2016 crwdns2935289:0USF Tampa, Team 6-3, Eyestone Spring 2016crwdne2935289:0
USFT-EYESTONE-S16S6G3
crwdns2947412:05crwdne2947412:0
Has anyone had to replace the digital volume control? Mine is intermittent. PCB solder joints all look good. I guess I will have to un-solder it to hopefully find a part number.
Richard Smith - crwdns2934203:0crwdne2934203:0
Has anyone had to replace the rotary encoder volume control? Mine is intermittent. PCB solder joints all look good. I guess I will have to un-solder it to hopefully find a part number.
EDIT: No markings on it, but one on Ebay seems close enough to try. The shaft looks a little longer than the original. http://www.ebay.com/itm/2PCS-Rotary-enco...
I’m experiencing the same issue with the volume control. Did you use this rotary encoder from Ebay and if so how did it work out?
Dan Gacek -
I used this procedure to install a phone jack that had more volume. It is hooked to the speaker with a switching jack. I just needed a little more volume. The above pictures made it possible to disassemble. I would have been lost without it.
Thanks
ironabby - crwdns2934203:0crwdne2934203:0
Mine just stopped working (not turning on.) Wall plug/charger light lights up. Anyone else have this issue? Any solutions to fix it?
TS Project - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,220
