If the Gourmia GAF536 Air-Fryer is not level, wobbles when being used, or is scratching the surface it sits on, these bumpers are the likely cause and will need to be changed. In this replacement guide, the steps required to replace the rubber bumpers will be provided.
Locate the 4 rubber bumpers on the bottom of the air-fryer.
crwdns2935267:0crwdne2935267:0Halberd Spudger$2.99
Use the halberd spudger to remove each bumper.
Once the damaged bumpers are removed, they can be replaced.
